I've got a 320 with 50k on it.
From the MoT I've been told there is a film of automatic transmission fluid on the bottom of the gearbox. They could not source it. I've had a look and it seems fairly uniform. Are there any probable sources I could check? It's a fine film and there's no drips on the garage floor (hence not realising the problem).
When I bought the car it had just been 'thoroughly' serviced by the dealer but after a couple of weeks I noted that there was oil coming from the power steering reservoir. It had been overfilled. (Very thorough!). Could this be the source of the leak?
I was going to get the autobox fluid changed at 60k so it's no big deal to do it now.
As an aside, I keep getting told off for not posting whenever I log on.
Premium Member 2001 SLK32 AMG
Well done for Posting.
Havent had this issue myself, hope it works out for you man.
Good luck,
RLander.
Have the transmission serviced and be sure they replace the pan gasket. This is not so much a paper gasket as a rubber seal, not tightened too tight.
I'd bet that it's the pilot bushing that is leaking. It's really a common issue on these trannys. Good news is it's inexpensive and fairly easy to replace. Google it when you get a moment and you'll see tons of 'how to' vids.
Thanks for that. I'll go under and have a look.
