This just happened, About 1/4 mile from work, I was driving about 25-35 mph, I felt a clunk sort of like the car down shifted a little stiff, haven't really felt that before. Then I notice that the BAS, ABS, and the Brake warning lights are on, also the gear number instead of D is just dark. I get to work and in a parking spot, the car is stuck in a higher gear than usual as I am pulling into the spot, then after about 5 seconds, all the warning lights go off and the car seems fine then.
Any ideas on this?
Any ideas on this?
From a site search:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com ABS BAS and brake lit up
Registered 2001 SLK320
90% sure its your Wheel speed sensor. Have the same problem with my Escalade. You have to replace the sensor, and or hub, if often comes"packaged" together. Check codes
As it did with my Magnum (there, it's called a "tone ring"). Scary when it happens, ain't it? :surprise:
The speed sensor is what I was thinking it probably is.
Previously a few months ago I had attempted to replace the transmission connector with a URO branded version connector, this was a failed attempt, however, I couldn't get the screen to engage to hold the connector in. I ended up using the o-rings from the new connector with the old one.
I pulled codes again with the iCarsoft the other day and was receiving the same codes as before, 1 for the transmission connector and 1 for the brake switch, along with 2 I can't find anything about.
I purchased the $16 connector from the dealer Friday. I removed the wire plug from the connector and there was oil in there. I removed and replaced the connector with the MB part and had no issues getting the screw to engage this time.
I sprayed cleaner on the connectors and blew dry everything and put it back together. I replaced the brake switch also.
So far so good, however, I am still thinking that I might need a speed sensor.
Which one though?
I tried to clear out the codes from the transmission with the scan tool, but it kept coming back as unsuccessful.
The codes from the ESP system that I read are P1200-001 and P1202-001
I drove the car home on the day that it went to limp mode without issue (about 27 miles) and then about 65 miles since I replaced the connector and brake switch without issue also.
