Registered 2005 SLK55 AMG
Hi all,
I have just updated the firmware from the download link I have seen on here but I'm not sure if it's the latest. I downloaded it from Mercedes.
The problem is I still don't see ETA on the satnav. Do I need to set something else up?
Please see the attached to show you the current firmware level I have updated it to. I reburned the CD but it said the same level of software.
Premium member 2001 SLK320
yes you do.
you can have it show you lat and long and height above sea level, or you can select ETA.
go to the Map button, get the map up. Press the display button. look at the options there and you will eventually find a choice for current position or ETA. select ETA. you won't know how high you are though>:D
I
Thank you so much for the response.... however, I did find it myself but thanks so much again. Upshot is I have successfully updated and I have ETA....yippee.. love this motor. I also saw a yt that talked you through changing the boot screen to AMG...looks ace ?
