I am a newbie here and just got my slk230 and it was not charging so I install a alternator and it is still not charging so were do I go from here any help would be welcome.
Thanks Richard
Charlotte NC
Sadly Woolly has passed away
When you say 'not charging', what are the symptoms? Charge warning light on all the time??, car won't start?? Have you measured the voltage across the battery with the engine on/off?
Moving this to the r170 general discussion
Not Charging
Battery voltage is good after charging it with a batter charger. The alternator is charging but it is not putting the charge to the battery.
And when I hook the battery up the park lights come on and the headlight switch starts to make a weird noise.
Thanks Richard
now charging
Found two blown fuse in the black box on the right fender apron in front of the battery. They were 125a and a 50 amp fuse. Now it is charging buttttttt it want change out of second gear it sat for five month before I got it. So what could this be going on with the transmission?????? And the PSE pump is toast that what was keeping the park light on.
Thanks Richard
Charlotte NC:confused:
