1 - 20 of 22 Posts
Hi, new to this forum, I have a 2006 slk55 amg and it will not crank. new full charged battery, put key in and turn it to on position and everything works as should, engine fan comes on as well not sure if that is normal, turn the rest of the way to crank and nothing not even a click. I changed out the start relay and nothing. both key fobs seem to be working fine. Here is a little history, took the hood off to paint... then started the car and it started slow as if low battery but it started, had it outside for about a week and went to start and everything else seemed to work fine but no crank. So I replaced the battery and made sure it was charged full first and anyway no crank. Does anyone have any ideas, thanks
Rob
Bill's Den: Documents
Lube those seals:
http://www.slkworld.com/226839-post1.html
your brochure:
mods you should do:
smarttop
clear or tinted side markers
shorty antenna
led license plate bulbs
led parking lights
carbon fiber center caps
See my mod albums for more ideas
FREE GIFT! Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car). If looking for a car, get the options before you buy!
Hi!
full charged battery? so it is a brand new battery or a battery that is not new but fully charged?
Premium Member 2005 SLK55 AMG
Hi Rob,and welcome from the UK Midlands! :)
I can't offer advice on your issue, but hope you get it resolved soon..
Registered 2005 SLK55 AMG
Check fuses. If all good, get under the car and jump power directly to the starter motor. If it doesn't spin, then....
Registered 2009 SLK200
Make sure battery is 100% percent a good one before you can proceed to any thing else like starter motor connections , key etc
Premium Member 2009 SLK55 AMG
Hmm..
May need scanning ...
Manual is saying to check the following
Power to the Ignition coils
DAS start enable signal not sent - scan needed
Voltage at the Main engine ECU
Was it left outside without the bonnet for the week ..?
My bad, it could be a bad EIS module.
Possible Eis key module
But first he needs to elliminate the car battery first as in a new one etc
Or a 100% used one if that makes sense .
Then its test starter motor then key then ............
Until he posts with update we are in limbo mode . :grin:
Discussion Starter #20
Update I do believe it got water in the E.C.M. I was talking to a merc. tech. and he said because it was outside without a hood and it snowed water got into the E.C.M. and created short that is why the engine fan comes on full when key in in on position. So now talking with a company that does E.C.M. repairs, it`s only money
1 - 20 of 22 Posts
