newbie
601 Views 6 Replies 7 Participants Last post by  ladyavenue
Hi,, new to the forums so first of all hi :)
Hoping someone can help that may have had the same problem i'm having. I have lost electrics to my passenger side door. i.e. all mirror movements. central locking & electric window power. But speaker still working fine so have ruled out the conection plug. :| . i plugged my diagnostic tool in (which came up clear) so a little bit at a loss. Many thank's for any info anyone can come up with,
Fiona :smile:
Reactions: 1
First please update your vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
See less See more
Welcome from Madrid..
Sounds like it could be the control module in the door, they're none to fail due to water getting in...
Hi Fiona, welcome from Barrhead, Scotland. :smile:
The attachment here show how to remove the left door liner and access the left door control unit, labelled N69/1. You could look to see if it shows signs of having got wet.
You may want to find someone that has the MB DAS diagnostic tool. It is about the only tool that can read all the controllers in the car (there are lots). If you used a generic OBDII tool to check for faults, those typically only look for engine fault codes.
