1 - 20 of 28 Posts
Hi!!
I'm Dianne from B.C.
I (hopefully) have posted a couple of photos showing rodent damage to the insulation on my battery box. Removing the engine to fix the problem (as suggested by Mercedes dealer) isn't an option. Any ideas on how to repair so this looks decent? Does it have to have insulation around this small area where it chewed?
Thanking you in advance! :)
Dianne
2012 slk350
Palladium Silver
White leather seats
Black Ash
https://www.mbusa.com/mercedes/service_and_parts/owners_manuals
https://www.mbusa.com/mercedes/service_and_parts/maintenance_manuals
mods you should do:
smarttop
Lube those seals:
http://www.slkworld.com/general-discussion/20937-spring-here~gummi-pflege-lube-your-seals-lithium-grease-your-joints-hinges.html#post226839
Your brochure:
Free Gift!: Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car).
Super Moderator......................06 SLK 280
Welcome to SLKWorld.com from Northern
California
:burnout::Beer:
List of Useful SLK Links >https://slk-links.neocities.org/Links.html
PARTS Information on Mercedes SLK R170 R171 R172 >https://slk-links.neocities.org/
We have a free to enter monthly competition.
Entry is open from the 1st to the 15th of every month. You simply post a reply with 3 photos.
After the 15th we usually open a poll for members to vote on their favorite.
Here's the main thread:
Benz SLK Forum
Hi, thanks for that reply. I'm not sure what sound proofing mat is...would that come from an auto parts store? That sounds like a good idea and I will check into it. Yes, that is the only area chewed. I'm still getting over the trauma, lol.
Your car is beautiful!
Thanks! Oh, I thought you meant my car :D
https://www.google.com/search?source=hp&ei=8YS-WtT0KIy7tgWr0KHoDg&q=sound+proofing+material+for+car&oq=sound+proofing+material+for+car&gs_l=psy-ab.3..0i10k1j0i22i30k1l8j0i22i10i30k1.1960.9652.0.9820.33.32.1.0.0.0.140.2976.22j9.31.0....0...1.1.64.psy-ab..1.32.2982...0j0i131k1j0i13k1.0.Nynlj60jhWI
Thank you for your comment regarding my SLK - I quite like it's looks too. Pity it's a lowly 200 but plenty good enough for my needs.
Sound proofing mat is what audiophiles use to quieten down interior noise so their music sounds better. It's quite expensive unless you could scrounge a bit.
Another, cheaper, option would be to visit a breaker and buy an under hood liner from anything that uses a similar material to MB.
see my post 7 with soundproofing links :D
Super Moderator
Welcome from Lakeland, Florida.
Super Moderator......................2012 SLK55
Hi Dianne, welcome from Ontario :smile:
_______________
Len
Roof rats can do major damage. Time to start a plan to remove all rat entry holes steel wool & get a couple of Rat zappers . Com. Maybe a few large rat traps baited with peanut butter & also a couple infrared sensors that send out a signal to deter them too!
First off the damage looks aesthetic and superficial, anyone that says you'd need to pull the engine to repair that is a thief, the damage would have zero effect on your battery or anything else, it would only be a problem because it isn't right and you know it's there (I understand). If it were me I would apply something like Great Stuff and smooth / form it with a putty knife then trim it after it expands (because it does), let it dry, shape it and brush it over with some flat black paint (all without removing the engine). for a cost of about $5 :nerd:
Great Stuff
Tack free in 6 minutes; Trims in 30 minutes
Foam elasticity allows for movement/shifting within a structure
Paintable, stainable and sandable
Cream colored foam
Cures rigid
All-direction dispensing
UL Classified
One 12 oz. can = up to 19 tubes of caulk
Patiently applied, trimmed and painted you could make it look like it never happened (all without pulling the engine). :|
I would also buy some mouse traps and a bait station to place in your storage area to prevent any further damage.
Good luck!
1 - 20 of 28 Posts
