1 - 20 of 27 Posts
Hi All,
Reporting in from Malaysia.
Just brought a preowned 2005 yr 280SLK Black, the new car here are so darn Expensive. Looking forward to getting many valuable knowledge in this forum. :)
Currently family has another C230K Coupe and... in the process of getting a vintage 1965 250SL (W113), ya, we are benz fanatic here. :hail:
Hopefully any malaysian forummer can keep me in contact but i stay in the Souther State, as i believe most of the Malaysian here will be from the Centre Region.
cheers
Escapee,
Thank you,
Founding Member #12/Moderator
Welcome from Michigan....
Discussion Starter #13
Hi all, is there any 'recommended' list of modification or maintenance that a new owner should look out for?
Lik I saw in another thread that the rubber seal for the openable roof can be quite problematic.
Mine is pretty stock except for a set of 19" wheels
1 - 20 of 27 Posts
