1 - 19 of 19 Posts
Kind of on a whim I purchased a red 2002 SLK230. It seemed to be in good shape except for it going into limp mode when flooring it. Presented low offer due to issue. Now I own one.
Cleaned the MAF and it seemed to help.
Took to dealer for Cam Position Leak. They replaced the harness, ECU, Upstream O2 sensor, and MAF at no cost. The cam position sensor replaced by myself today due to leaking. They no longer do this as a part of the campaign.
Divers door lock had broken vacuum connector. Fixed at no cost.
Replaced Transmission spacer connector.
Engine was still coming on but is currently off since spacer replacement.
Dealer said Transmission controller needed replaced and new lines. Cleaned up new lines and no leak. Wait and see about controller.
Have Autoenginuity for computer coeds.
Currently running good with no issues except occasional limp mode. Turn if off and back on again and OK. Seems to occur when you floor it.
Thats my story so far.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Premium Member 2005 SLK55 AMG
Hi and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us! :)
Registered 2002 slk 230
Welcome to SLKWorld. Good luck with your newly-purchased SLK!
It sounds like a fun project!
Premium Member 2004 SLK200K
Welcome from Madrid...
Have you had the solid wire adapter installed to prevent oil sepage from the Cam sensor again ?
Premium Member 2009 SLK55 AMG
My SLK220 2002 also has transmission problems..should have looked for a manual....but working on them !!!
Good luck with yours !!
KevinJ
1 - 19 of 19 Posts
