1 - 20 of 21 Posts
Yes, per its vin number
From a member with a SLC 2017
Identification number: WDD1724661F132867
also from Wikipedia,
For the 2017 model year (late 2016), with the release of the third generation R172 facelift, the SLK-Class will be renamed to Mercedes-Benz SLC-Class in accordance with the revised nomenclature adopted by the brand. Under this scheme, roadsters use the base name "SL", followed by the model's placement in Mercedes-Benz hierarchy. The "SL" is for Sportlich Leicht (German for "Sport Light") and alludes to the long-running SL-Class. This is followed by the letter "C"—the SLC being the roadster equivalent to the C-Class.[3][4]
It you want a step backwards....sure! :D
I know! Me too! :D
They are wrong. Even MB says it is a R172. Who you want to believe? MB or someone that is not with MB
Plus the vin above says 172 in it :D
As mentioned, the SLK/SLC has a mid 7/8 year facelift
r170 started in 1996 and had its facelift 2000
r171 started in 2004/5 and had its facelift 2008/2009
r172 started 2011/12 and has its facelift 2016/2017
Was it you that was supposed to correct Wiki's r173 entry or someone else we spoke to?
1 - 20 of 21 Posts
