Now another problem developed that is malfunction of central locking..! I can unlock drivers side door or trunk manually but not with remote ! It closes by remote fine ! The problem is that armrest storage cant be opened manually to my knowledge..any suggestions or experience how to open it ?
Start simple. Check your PSE and see if it's wet. As a tip, it helps to put the year of your car in the info section as there are some issues that are only pre and post facelift.
his year is in there...2002 :D
I'm assuming that the fuel filler flap is locked as well as it's on the same line as the centre console?
[There is a separate emergency release mechanism for the fuel filler flap inside the trim]
But if you can pull off the line at the front of the PSE and give a short sharp blow into it either by mouth or syringe (only takes a couple of lbs of pressure) you should theoretically be able to pop both of those locks
