1 - 20 of 20 Posts
Just bought a 2002 SLK 230 and this seems to be THE place to keep it as it should be. The forum has been very useful in sorting out various common issues already so I thought I must say hello and thanks for all the useful info.
One very simple question - checking the auto transmission fluid level hot mine appears to be too high - the level is above the black plastic calibrated end of the dipstick and it about 10mm up the flexible metal part. The transmission works fine. The engine temp sits above 80C which is over the spec for measuring the fluid level - is the running temperature critical enough that a few degrees would make this difference or is it simply that the PO overfilled the ATF?
Thanks for any comments.
Ray
Ipswich UK
Super Moderator
Welcome to SLKWorld.com from Northern
California
:burnout::Beer:
List of Useful SLK Links >https://slk-links.neocities.org/Links.html
PARTS Information on Mercedes SLK R170 R171 R172 >https://slk-links.neocities.org/
We have a free to enter monthly competition.
Entry is open from the 1st to the 15th of every month. You simply post a reply with 3 photos.
After the 15th we usually open a poll for members to vote on their favorite.
Here's the main thread:
ROTM Submissions & Voting - Mercedes
Benz SLK Forum
Super Moderator
Hi Ray,
@Dave2302 @M4rCu5 @Turdo2 Will brief you on the transmission when they drop by.
Welcome from Wirral, England.
Some guides on how to use forum features https://www.slkworld.com/forum-operations-help-center/536527-links-how-threads.html
For FAQs (contains explanation of how and what to do things as well as forum rules
See:- https://www.slkworld.com/faq.php
Entry is normally open from the 1st to the 15th of every month. You simply post a reply with 3 photos.
After the 15th we usually open a poll for members to vote on their favourite.
https://www.slkworld.com/rotm-submissions-voting/
New members are welcome to enter (and they win too!).
This could be you in 12 months: https://www.slkworld.com/rotm-winner/535415-2018-slkworld-ride-year-winner-simplyslk.html
Really useful links (thanks to ixions cataloguing)
https://www.slkworld.com/general-discussion/354330-links-toparts-assemblies-technical-data-locations-parts-slks.html
https://slk-links.neocities.org/ Includes diy videos.
Spare parts: https://slk-links.neocities.org/EPCLINKS.HTM
A brief guide to the forum and how to get the best from it:
https://www.slkworld.com/new-members-introduce-yourself-here/439993-new-wondering-what-do.html
There's a link to R170/171/172's do it yourself threads under the pic below.
Some useful tips in this section for new and prospective owners.
Worth knowing are reset adaptive learning, check list, Spring is here and what is the SmartTop.
https://slk-links.neocities.org/BUYING.html
You can find your region by scrolling down the page on this link
https://www.slkworld.com/forumindex.php#club-regional-discussion-forum
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome new members as we welcomed you to obtain your needed posts to PM/edit. You can always pm a moderator/administrator.
Want to ‘like’ or thank’ someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any post you like. This saves you having to comment or use the 'quote' button so we know who you are asking or replying to or referencing.
Administrator/Founding Member
Ray
Ipswich UK
Hi Ray, welcome :)
A few observations..
Do you have the engine running?
The 'usual' way to check the fluid level is to get the car on level ground (ideally a lift) and measure the trans oil pan temp with an infrared thermometer - 80c - Car ticking over in Park
ATF expands as it gets hot so that's an interesting question that @Dave2302 is more qualified to answer than I am because I've never heard of anyone checking the level with the temp above 80c :surprise:
Where did this dipstick come from? It is correct for MB I assume?
Kent has put together a few useful videos for perusal:
HTH
Hi and thanks for the input.
Yes the dipstick and method I'm using are correct, I think my question is really about how accurately does the transmission need to be 80C. I was using the engine coolant temp as a rough guide - that's the 85C approx it was at. If the real life requirement is take the car for a 10 min run to warm it up then that's simple and I clearly have too much ATF. If I need to precisely measure the transmission temp and only measure the level when its exactly 80C it can be done but its going to be a pain to do.
I didn't think about using an IR thermometer so I'll give that a go. IR thermometers are only as accurate as the surface emissions from whatever surface you are measuring but probably the black transmission pan will be near enough.
It'll be interesting to hear what the real life method is.
Thanks again
Ray
Super Moderator
Hi Ray, welcome from Canada :smile:
Dont overthink it.. If it's shifting fine and the fluid isn't low, then you are good.
I HAVE experienced decent fluctuations in level based on temperature.
Super Moderator/Florida Event Coordinator
Hi from Florida!
Hi Ray, Welcome from the Sacramento Valley SLK Enthusiasts!
1 - 20 of 20 Posts
