1 - 14 of 14 Posts
It is in the diy section
Thank you,
Founding Member/Moderator
Welcome to the forum...that cabin air filter is a pain to replace, but worth it...i found the nastiest things inside mine, good thing i changed it the first few weeks after i got the car.
definately a pain. you need to be a contortionist!!
Premium Member 2006 SLK350
An additional suggestion...people have suggested using duct tape to help seal the box. I would suggest you try tuct tape - used to seal overlapping plastic vapour barriers. Duct tape dries out rather quickly, becomes brittle and looses its adhesion.
Welcome from Michigan via Dallas Texas.......
Welcome from Maryland! I hope my mechanic can do it cheaper than MB as mine is due for change at next service!! Not much of a contortionist per JBanks.
1 - 14 of 14 Posts
