1 - 14 of 14 Posts
Hi Bob here, new member.
2002 230K purchased in Sep 2010 - really pleased with it. However, outside temp sensor started showing 15 deg higher so had dealer replace it only to find when car was returned, brake warning lights started coming on within 1 or 2 minutes randomly or when selecting drive, then car going into limp mode.
Dealer claimed found a wiring problem but fault still apparent. Now they're going to change the ECU, so we'll see when I get the car back this afternoon.
Been interesting reading through previous posts on this issue.
Thank you,
Founding Member/Sergeant-at-Arms/Moderator
Welcome from Michigan.....
Founding Member #2
1 - 14 of 14 Posts
