1 - 13 of 13 Posts
Registered 2000 SLK320
Im been searching around on here but cannot find any pics of the cat fitted to my slk200
is this center box the cat .or a second resonator ?
Cat's are up front one either side attached to the exhaust manifold and two on the front of the front pipes that lead to the resonator box that's on the V6 yours be slightly different.
Regards Stuart.
Discussion Starter · #4 ·
Thanks ,i couldn't see any more boxes on the exhaust ,guess they are tucked away
so easiest option is to replace this box with a straight pipe ,Mines rattling away and the car sounds like a bag of marbles
Discussion Starter · #7 ·
This is the only other box on the system (i was looking for twin pipes as id seen on other pics)
so this must be the cat and its this that seems to be rattling
Do they make a cat replacement pipe this shape for the early slk ?
Founding Member 2006
delete button or edit at the bottom of your post
if you just got to 15 posts, you have to wait until the system updates/refreshes for your new status
until then, what do you want deleted?
Seems to be gone now thanks ,but i cant see a edit button i must not be posting enough
you must have just recently got to 15 posts
i checked your status and you now should see a 'edit' button at the bottom of your posts going forward
let me know.
i edited your previous posts to remove duplicate :D
Just above the cat there is a heat shield that often comes loose.....hopefully that'll be your problem, four new studs, four washers and four bolts problem sorted
Fingers crossed
1 - 13 of 13 Posts
