1 - 10 of 10 Posts
Hi Dan,
I am not sure if its me being paranoid but recently (just turned 22K miles) I have noticed what I think is "different"l background engine noise which is audible at low rpm. I would describe the noise as a low pitch Hoover and it disappears as soon as I accelerate.
I have noticed this after my first full tank of unleaded 98 octanes.
Do you think there is a causative effect between the new engine noise and the petrol?
should I worry and have the car checked?
does the sound produced by the engine change with time as a rule?
I apologise for the basic questions that will sound ridiculous to the experts
Thanks in advance for your help
P
D
Guest
Alright mate,
Personally i would not worry about it if it was anything major you would know about it.
Try taking it off of 98 for a little and see if the noise disappears.
The engine sound will change as the engine matures but i don't think that explains this noise, it could be one of the pumps also just activating.
Thanks for your answer Dan,
I will take it off 98 as you suggested and see what happens.
Sounds like we have to be careful nowadays , have you seen the news about the petrol having a high ethanol concentration which has damaged a good number of cars this week?
P
D
Guest
Yeah did see something about it had a busy week so not had much time to look in-depth at the stuff thats been out but i will do.
See what happens once its off the 98 it might make a difference but i would not worry about it even if the noise does not go its probably just a pump or valve
took it off the 98, noise still there and irritating .., now that the top is down. I had it checked by a dealer, they confirmed that there is nothing major but would like to change a part of the supercharger and of the air con. I am giving them the car on the 3rd it will be fixed in a day I will keep you updated.
P
Quick update
The cause of the background whining noise was a fault with the air conditioning charger. In addition there was some damage of the exhaust pipe, apparently a welding gave way. The car has been fixed, and I love it even more!
thanks
P
D
Guest
Glad its sorted.
Sorry to hear about the bad weld that does not happen very often.
1 - 10 of 10 Posts
