Registered 2002 SLK 230 R170
Help required please - I Need to Locate the CAN BUS inside the Cabin of a R170 Face Lift (2001).
I know I can go to the engine compartment and connect to one of the Black Box's there.
But I would then need to go through the Bulkhead to get it to the cab - Plus a long run of wire to get it where I want it.
Would it be OK to connect to the under-dash socket with a V splitter cable so the garage can still do a diagnosis.
Also would I have to put a terminating resistor across the twisted pair wires I would end up with.
Mike
On the 98 model there are two buses, engine and interior, which devices do you need to snoop/intercept?
Z37/2 and Z37/3 are engine CAN lo and hi connector sleeves under the passenger carpet and equipment bridge.
Thanks for reply
I am trying to intercept body functions. Windows, Door Locks etc.:wink:
Mike
On a 98 at least, you probably want the bus between the PSU and MFCU then - but that bus doesn't stop inside the cabin AFAIK. You could try the above engine bus but you may not see the messages you need to see.
Smarttop attached under hood of R170 model.
Check the R170 Smarttop install thread for maybe some ideas
I need to find the enginebus of my R170, do you know where i can find this?
