1 - 16 of 16 Posts
Anyone know how to unlock the theft code on a used comand 4.5 with Vediamo? My comand in my 2013 slk locked up and not working. I need step by step directions for removing theft lock and codeing the comand to my slk. Thanks, Michael
I have the theft code. Just need directions on how to code it. Is it different then coding a new one?
Did you originally have a comand that died or are you trying to retrofit?
Unlocking and coding are separate items.
Thanks for the info but the dealership does not have access to that anymore. Tech said that is 2017 Star system.
If a dealership is doing this the code will be requested during initial startup and then scn coded.
A dealership will not use vediamo.
If you are doing this at as dealership then they must update your data card and then did the automatic setup.
Discussion Starter #14
Ok, my data card has the radio code is 523 but needs to be 512. Tech can remove the 523 in vdoc but can not add the 512. Says its not compatible with my vin. Any body have the ability to change it for me?
1 - 16 of 16 Posts
