1 - 15 of 15 Posts
Hello Everyone...
I'm a new member. my left side small window doesn't close when I operate the automatic roof.
Does anyone have any idea what could be the cause of this. Please help.
And is it easy to remove the panel which gives u access to where it's motor is located?:( Thanks
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model and year.
Usercp at the top of page, edit your details, location/vehicle.
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
And finally, if you find something useful on your visit here today, perhaps something that saved you time or money, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! At the top of the page, click ‘Donate’ or Help Donate’. Thanks!
Premium Member 2006 SLK350
Mayra...does the window function ok otherwise (with the switches)? If so, it may be the sequencer or there is a micro switch sending a false signal.
Common problem in cold weather. Try this: After the roof is up, give the window up control for that side a tug. Also only put the top up/down in warm weather.
Hi Happy Holidays!!
thanks for your response, I probably need to put more information...the car is a 2003 slk 230 komoresor
both large windows are fully functional with their switch...the problem is with the small one on the left side...When open the roof/convertible top the left side doesn't close.
Happy Holidays to Everyone
Thanks for all your responses....and "Happy Holidays"
Excuse me but I really don't know yet how to move around or respond to each of you in these forums.
Welcome from Michigan....
Premium Member 1998 SLK230
Welcome aboard
when you put the roof down the small windows are supposed to stay down.
are you saying when you put the roof up the left small left window does not go up?
Per ardua ad cineris.
Dealing with an old thread, for the thread hunters.
The small window is controlled as part of the roof cycle, and is explicitly not under user control.
It is left down with the roof open so that the small sharp spike is not in place to cause injury.
Access to the motor and mechanism is behind the carpet that covers the rear bulkhead.
Chances are that this window, like all the other ones, has got sticky with time, and just needs a service. You may be able to raise it by having the door open as the roof is closed, and then once the roof latches have engaged and the other small window starts to climb, pull up on the left small window to assist the motor.
With regard to actually fixing it, I cannot help; I've not been there for that.
I'm pretty sure I've seen the wiring when fitting rear speakers.
Threads like this one (TBD) deal with the actual task.
1 - 15 of 15 Posts
