Hello,
I live in France so I hope my english will be good enough for you to understand my problem ...
My SLK has not been used for about one month (SLK 200 from 1997).
When I turn on the contact key, then the starter does not work, but instead the radiator fan starts ...
I tested every fuses, they are all OK. The battery is new and tested OK.
Does anyone know what may be my problem ?
Thanks !
Premium Member 2002 SLK230K
Welcome from New Hampshire, do a search for the K40. Here in the USA we had/have problems with that circuit board in the past.
Premium Member 2013 SLK250
It has been setting for a month, battery might be to weak to start the car but has enought power to run the fan a some other items. Starter takes a lot of battery power to work.
Thanks a million !!! I found a few people having the same problem as mine and saying the K40 may be the problem ...
So I will now investigate this way ...
Thanks again !!!
No problem, my slk had the same problem last year even though its a face lift model i looked at the K40 anyway. What i found was some of the solder joints were cracked, after a quick repair the car runs great now. The cracks were small i could only see them with a magnifying glass.
