Hey everyone,
Just wanted to give a shout out for a local plating company that I just did some business with.
I had my OEM rotors for my Mercedes SLK55 AMG zinc plated and they did an awesome job. They only charged me $45.00 :tu:
If you have anything that needs to be plated give them a call.
The OEM rotors come from the factory with a cold galvanizing spray coating on them which does not hold up all that well and eventually starts to rust through. Now they are fully protected :)
Here is the company info:
Gleco Plating
2220 Grisham Dr. Rowlett, TX 75088
Phone: 972.475.4300
Ask for Mike Ray, the general manager.
Here are some before and after photos:
Before
After
Thanks! I moved this is out of the club section to repair shops
Founding Member #2
It looks good but won't it affect the friction coefficient and thus the braking performance?
etyu,
Thanks! :tu:
To answer your question, no it will wear off of the braking surface after the first time you apply the brakes.
That is why a lot of people use zinc on rotors is because it is soft enough to wear off quickly but strong enough to protect the rest of the rotor from corrosion.
