I have a 99 slk230. 120,000 klms. Recently when i drive it when i accellerate from standstill i have to wait 2-3 seconds before i gain any responce and accelleration and then it accelerates as expected.
When i first start engine accelleration is responsive for the initial accelleration however any subsequent occassions from standstill it has this 2-3 second delay
Any ideas if there is anything i can try and reset before i go investing in replacing sensors etc which i am advised is not a cheap excersise
also during these times when i am experiencing the above i find that the speed limited does not work and instead the display shows --- and beeps several times
Have seem similar. POssibly the engine management not allowing the turbo to boost (holding the wastegate open) which can result when the ECU is getting unexpected results from some sensors, such as airflow, manifold pressure, etc. etc.. Sadly, not a quick diagnosis. Need someone who has good familiarity with the specific engine.
Not sure if your model has a clutch on the SC (supercharger) or is directly coupled. If it does have a clutch, it will not engage until 1700-1800 RPM indicated. While looking at the SC, raise the RPM to see if the clutch does work. If the SC is working as advertised, start to look at the the forced induction plumbing. You could very well have a line ruptured or disconnected / loose. Start with the easy things first before "shot gunning" parts. A close visual inspection can save you a lot of money.
