1 - 20 of 342 Posts
Dropped the Beast off at C2Design this morning and handed over the key.
Will be brought in and placed on the lift and operation begins 1st thing Monday morning. More pics and updates as the job progresses.
good stuff starts post 37, 45, etc
There are a ton of pics and pages and videos...don't miss any
Founding Member #2
As PropDr stated: got LSD (the limited slip rear differential, not the psychogenic medication)?
Discussion Starter #10 (Edited)
I will get an LSD next after I make sure everything is copasetic
Good luck with the install Jeff.
I hope they look after your baby:smile:
Discussion Starter #14
Daniel, with that picture, you made me sooo hungry :D
Discussion Starter #16
Nope. :D why do you think it should be upgraded other than spending my money :D
Discussion Starter #17 (Edited)
Inside and safe
Waiting on Monday!
Discussion Starter #18
ECU overnighted out on Monday to Colorado for programming for SC/headers/etc
Founding Member #2
Will you need to upgrade your suspension also?
Good point: may need the Nurburgring rated suspension found in the P030 package, should be straight swap; in addition to the LSD. Otherwise it will be hard going around corners at reasonable velocity without the rear wanting to spin out.
Discussion Starter #20
I will not be going around any curves or corners :D
LSD is next mod.
1 - 20 of 342 Posts
