21 - 29 of 29 Posts
Discussion Starter · #22 ·
Electrical:
Correctly adding an accessory using an 'add-a-fuse' to an SLK.
Correctly adding an accessory using an...
How to Replace batteries in your keyfob with Pictures
DIY : How to Replace batteries in your keyfob with Pictures
Built-in Garage Opener - How To Program
R171 : DIY : How To Program the Garage Door Opener in Your Benz VIDEO
Solar panel to keep the battery topped up
Fitting a solar panel to keep the battery topped up
Remove and repair heated seats
How to guide: Remove and repair heated seats
Radar Detector Install!
The Great Radar Detector Install!
Retrofit electric seats
DIY - Retrofit electric seats
Fuel pump replacement
R171 Fuel pump replacement
Siren Replacement SLK55 AMG
Siren Replacement SLK55 AMG (2005)
Fix for A/C not working or intermittent, windows fogging up (caused by bad SAM)
DIY Fix for A/C not working or intermittent, windows fogging up (caused by bad SAM)
radiator fan and power steering pump removal
maintenance position for the wipers
Does the SLK have a maintenance position for the wipers?
Discussion Starter · #24 · (Edited)
Post 2
M272 engine throttle clean
mercedes benz slk 350 M272 engine throttle clean
DIY Fix for A/C not working or intermittent, windows...
Spark plugs on a 200 kompressor (M271).
Replace the Cam Solenoid Magnet Error Code P0025 Fix.
SAP Secondary Air Pump Removal.
2006 Slk 280 cooling fan and fan shroud pics & steps courtesy Reb_Tn_06.
2006 Slk 280 cooling fan and fan shroud pics & steps...
How to change your spark plug wires-112-113-272-273 motors, most V6 & V8s.
How to change your spark plug and wires for the...
'05 SLK 350 Oil Sensor replacement.
Under Hood LED Lighting.
DIY - Under Hood LED Lighting
DIY Vacuum Pump SLK 200 1.8L
https://www.slkworld.com/slk-r171-class-diy/28591-spark-plugs-200-kompressor-m271.html
R171 spark plug change (M272 engine).
DIY: R171 spark plug change (M272 engine)
Transmission
Discussion Starter · #27 · (Edited)
Recently added.
Bluetooth puck and pairing.
Radio/speaker cutting out
Discussion Starter · #29 ·
DIYs yet to be assigned
21 - 29 of 29 Posts
