1 - 20 of 29 Posts
We are in the process of creating DIY sections (eg Brakes, Lights etc).
The chaos below is merely a holding place whilst this work is in progress.
Good reference site
STAR Service Manual Library -- Awesome!
Mercedes-Benz Do It Yourself DIY Repairs. Includes link to online owners manuals.
Restoring How Tos for the R171
How to Replace batteries in your keyfob with Pictures
DIY : How to Replace batteries in your keyfob with Pictures
Built-in Garage Opener - How To Program
R171 : DIY : How To Program the Garage Door Opener in Your Benz VIDEO
INTERIOR
Repair of the seat that "snaps" into the curves NEEDS ADDING
*Remove and repair heated seats
How to guide: Remove and repair heated seats
*Radar Detector Install!
The Great Radar Detector Install!
*Retrofit electric seats
DIY - Retrofit electric seats
Windrestrictor installation
R171 Windrestrictor installation
Repairing the R171 Trunk Divider Pegs
DIY: Repairing the R171 Trunk Divider Pegs
Custom trunk inserts
DIY: Custom trunk inserts
ENGINE
Water in battery compartment
M272 engine throttle clean
mercedes benz slk 350 M272 engine throttle clean
*Fuel pump replacement
R171 Fuel pump replacement
*Siren Replacement SLK55 AMG
Siren Replacement SLK55 AMG (2005)
Check your antifreeze
It's a Perfect Day to Do Something?
*Fix for A/C not working or intermittent, windows fogging up (caused by bad SAM)
DIY Fix for A/C not working or intermittent, windows fogging up (caused by bad SAM)
Check your Balance Shaft Sprocket in 10 minutes.
Video: Check your Balance Shaft Sprocket in 10 minutes.
radiator fan and power steering pump removal
How to change the oil on Mercedes Benz 2008 SLK 280
DIY: How to change the oil on Mercedes Benz 2008 SLK 280
EXTERNAL
maintenance position for the wipers
Does the SLK have a maintenance position for the wipers?
SERVICE creaky door mirror
Rattle left rear - finally sorted!
Guide to Lubricating Sticky Rear Windows
ROOF
1. DIY: Custom trunk inserts
Elec done.
Discussion Starter · #2 · (Edited)
*Correctly adding an accessory using an 'add-a-fuse' to an SLK.
Correctly adding an accessory using an...
ENGINE & TRANSMISSION.
Engine
removal of plastic gasket cover for SLK 200 R171 engine M271.944
Detailed removal of plastic gasket cover for SLK 200...
DIY Fix for A/C not working or intermittent, windows...
*radiator fan and power steering pump removal
Removing the engine covers from top of engine.
https://www.slkworld.com/slk-r171-class-diy/460058-removing-engine-covers-top-engine.html
*SLK P0015 P0012 P0022 P0025 Error DIY.
SLK 200 R171 Oil Filter Housing/Oil cooler change/ seal change.
SLK 200 R171 Oil Filter Housing/Oil cooler change/ seal...
*Spark plugs on a 200 kompressor (M271).
SLK 200 Tappet / Lash Adjuster DIY Replacement.
DIY Oil Change for SLK350 with Pictures.
*Replace the Cam Solenoid Magnet Error Code P0025 Fix.
Idler pully replacement.
idler pully replacement
Replaced oil separator, Drain Pan and Housing Cover.
*SAP Secondary Air Pump Removal.
SLK AMG Air Filter Install.
SLK AMG Air Filter Install courtesy of Dr Eddy etyu
Drain/fill in coolant ENGINES 272.
Drain/fill in coolant ENGINES 272 in MODEL 171 courtesy...
Removing covers. Also see pdf in Green Filter replacement below
If you want to work on the engine, you will probably need to remove the covers:
*2006 Slk 280 cooling fan and fan shroud pics & steps courtesy Reb_Tn_06.
2006 Slk 280 cooling fan and fan shroud pics & steps...
* How to change your spark plug wires-112-113-272-273 motors, most V6 & V8s.
How to change your spark plug and wires for the...
Fluid changes. Oil Change Coolant/Antifreeze Flush Power Steering Fluid.
DIY Oil Change Coolant/Antifreeze Flush Power Steering...
DIY Power Steering Wheel Fluid "Change".
Oil filter housing. (photos lost).
Oil Filter Housing replacement. Unable to replace photos.
Oil filter disassembly.
*'05 SLK 350 Oil Sensor replacement.
Sepentine belt & pullies.
Hear whining? Good place to start:
Complete Serpentine (Poly-V Belt) Replacement DIY M112...
Oil Breather.
Smell oil burning and can't find a leak? Try this:
Resealed my leaky oil breathers today!
DIY: Valve Cover Breather Cover Job.
Green filter replacement.
R171 AMG55 Green Filter Install PDF
*Under Hood LED Lighting.
DIY - Under Hood LED Lighting
*DIY Vacuum Pump SLK 200 1.8L
R171 Change Motor Mounts.
Complete Serpentine (Poly-V Belt) Replacement DIY M112 & M113 Engines.
https://www.slkworld.com/slk-r171-class-diy/160705-complete-serpentine-poly-v-belt-replacement-diy-m112-m113-engines.html
Oil Change Coolant/Antifreeze Flush Power Steering Fluid Change.
https://www.slkworld.com/slk-r171-class-diy/171394-diy-oil-change-coolant-antifreeze-flush-power-steering-fluid-change.html
manual transmission and diff oil change.
https://www.slkworld.com/slk-r171-class-diy/340225-diy-manual-transmission-diff-oil-change.html
Fuel filter change.
https://www.slkworld.com/slk-r171-class-diy/24440-fuel-filter-change.html
https://www.slkworld.com/slk-r171-class-diy/28591-spark-plugs-200-kompressor-m271.html
*R171 spark plug change (M272 engine).
DIY: R171 spark plug change (M272 engine)
Water in battery compartment.
DIY Servicing Auto Trans . . . Penny wise, pound foolish?
DIY Servicing Auto Trans . . . Penny wise, pound foolish.
SLK 200 UK Oil and filter replacement-with images.
slk-55-oil-and-filter-change courtesy cyberdrakon.
Transmission
Discussion Starter · #3 · (Edited)
EXTERNAL
Door hinge removal.
How to Change your R171 Door Hinge - the easy way !
Remove door lock and repair Infrared sensor .
DIY : Remove door lock and repair Infrared sensor
Rear light cluster removal
Also useful for dismantling boot/trunk interior.
R171 Tail lamp removal procedure
side skirt removal from 05 R171 Anyone undertaking this please take photos. None in thread.
Wheel refurb.
I will be posting up a DIY for wheel referbs!
Spoiler removel/replace
2 parts.
DIY: rear spoiler removal and install, part 1
Spoiler removal and install, part 2
Rear sway bar & stabilizer bar replacement.
DIY: Replacing the rear sway bar/stabilizator bar link
Replace bank angle and slip ring /clock spring.
replace bank angle and slip ring /clock spring part 1
Exhaust manifold remove/repair/replace.
DIY: SLK55 R171, Exhaust Manifold Removal, Repair...
Rear Differential Jack Pad for SLK55 AMG.
DIY Rear Differential Jack Pad for SLK55 AMG
Diy 350 exhaust bracket.
Replace ROTORS and PADS 05 SLK.
DIY Brake job.
DIY Brake job
Lubricating Sticky Rear Windows.
https://www.slkworld.com/slk-r171-class-diy/446834-guide-lubricating-sticky-rear-windows.html
*How to strengthen signal using the R170 Antenna.
https://www.slkworld.com/slk-r171-class-diy/138585-how-strengthen-signal-r170-antenna.html
Brake Rotor Turning Limits.
https://www.slkworld.com/slk-r171-class-diy/164314-brake-rotor-turning-limits.html
Build a Brake Pressure Bleeder for $30.
https://www.slkworld.com/slk-r171-class-diy/473329-build-brake-pressure-bleeder-%2430.html
*Installing motor with memory for mirror dip on reverse.
https://www.slkworld.com/slk-r171-class-diy/477841-r171-installing-motor-memory-mirror-dip-reverse.html
Smarten the look of your disc brakes and painting calipers!
https://www.slkworld.com/slk-r171-class-diy/228617-smarten-your-disc-brakes.html
Replacing rear springs and shocks.
https://www.slkworld.com/slk-r171-class-diy/196217-replacing-rear-springs-shocks-r171-courtesy-mchild.html
*Curb Alert Pro install SLK55
https://www.slkworld.com/slk-r171-class-diy/229569-curb-alert-pro-install-slk55.html
Jack stands, DIY Xmas Project
https://www.slkworld.com/slk-r171-class-diy/486929-my-diy-xmas-project.html
Discussion Starter · #4 · (Edited)
INTERIOR
Facia/Dash restore.
DIY: Take apart Audio 50 APS HU restore front plastic...
Comand screen scratches. Restoration.
Lateral glove box door.
How to replace SLK steering wheel.
*DIY Paddles.
DIY Paddles
AC Vent Removal.
AC Vent Removal
*Gauge Cluster Removal & 120kph speed alarm
*Cheap and Simple solution to make Audio 20 Aux IN.
DIY repair attempt of sticky, malfunctioning buttons (and corrosion) in Comand APS.
DIY repair attempt of sticky, malfunctioning buttons...
*"HomeLink" Home Made (ALSO USEFUL IF YOU WANT AN ADDITIONAL BUTTON).
https://www.slkworld.com/slk-r171-class-diy/181282-[diy]-homelink-home-made.html
NTG2.5 Replace LCD.
NTG2.5 Replace LCD
*Seats, retrofit electric.
*Heater or Noisy Fan
Damp patches on the passenger carpet?
Heater noisy, or stopped working?
How to remove 2005 Mercedes SLK200 blower fan motor assembly
*Retrofit COMAND NTG 2.5 --APS(NGT) 50.
*Replacing faulty MFD panels - a.k.a. 'frying the shrimp'.
Replacing faulty MFD panels - a.k.a. 'frying the...
*Retrofitting a 2009 audio 20... make that a Comand 2.5
Retrofitting a 2009 Audio 20
*DIY Aux-In for Audio 20.
*Fixed my crackling and buzzing Harman-Kardon speaker.
*Custom boost gauge pod in dash.
*R171 350 Heater / Blower Regulator Replacement.
*SLK R171 head unit removal (youtube by benzwerks).
https://www.slkworld.com/slk-r171-c...r171-head-unit-removal-youtube-benzwerks.html
*DIY - Retrofit Linguatronic NTG 2.5 (R171).
https://www.slkworld.com/slk-r171-c...fit-linguatronic-ntg-2-5-r171.html#post228071
*Up/Down Shift Buttons to AMG Paddles Upgrade (pre-2006).
https://www.slkworld.com/slk-r171-class-diy/194033-up-down-shift-buttons-amg-paddles-upgrade-pre-2006-a.html
*USB Port Addition.
https://www.slkworld.com/slk-r171-class-diy/258601-usb-port-addition.html
*Rear window regulator replacement.
https://www.slkworld.com/slk-r171-class-diy/371753-rear-window-regulator-replacement.html
Trunk Struts Replacement.
https://www.slkworld.com/slk-r171-class-diy/20064-diy-r171-trunk-struts-replacement.html
*Install Aftermarket radio to replace Audio20.
https://www.slkworld.com/slk-r171-class-diy/11993-r171-install-aftermarket-radio-replace-audio20.html
Cupholder into pop-out Ipod Holder/change/phone, etc *PICS
https://www.slkworld.com/slk-r171-class-diy/5373-cupholder-into-pop-out-ipod-holder-change-phone-etc-%2Apics.html
*Take apart Audio 50 APS HU restore front plastic panel / fascia.
https://www.slkworld.com/slk-r171-class-diy/462481-diy-take-apart-audio-50-aps-hu-restore-front-plastic-panel-fascia.html
*Denison Gateway 500 / Escort 9500ci Install.
https://www.slkworld.com/slk-r171-class-diy/9065-diy-r171-denison-gateway-500-escort-9500ci-install.html
*Installing a Climatronic Module.
https://www.slkworld.com/slk-r171-class-diy/479393-installing-climatronic-module-my-2010-slk.html
Grease against squeaking seat
https://www.slkworld.com/slk-r171-class-diy/425434-diy-grease-against-squeaking-seat.html
Discussion Starter · #5 · (Edited)
ENGINE
*SLK 200 R171 Oil Filter Housing/Oil cooler change/ seal change.
Oil Breather.
http://www.slkworld.com/slk-r171-class-diy/134082-diy-valve-cover-breather-cover-job.html
http://www.slkworld.com/slk-r171-class-diy/11054-r171-amg55-green-filter-install-pdf.html
http://www.slkworld.com/slk-r171-class-diy/141065-diy-under-hood-led-lighting.html
http://www.slkworld.com/slk-r171-class-diy/175682-diy-vacuum-pump-slk-200-1-8l.html
http://www.slkworld.com/slk-r171-class-diy/204002-r171-change-motor-mounts.html
http://www.slkworld.com/slk-r171-class-diy/160705-complete-serpentine-poly-v-belt-replacement-diy-m112-m113-engines.html
http://www.slkworld.com/slk-r171-class-diy/171394-diy-oil-change-coolant-antifreeze-flush-power-steering-fluid-change.html
http://www.slkworld.com/slk-r171-class-diy/340225-diy-manual-transmission-diff-oil-change.html
Fuel filter change.
http://www.slkworld.com/slk-r171-class-diy/24440-fuel-filter-change.html
http://www.slkworld.com/slk-r171-class-diy/28591-spark-plugs-200-kompressor-m271.html
Discussion Starter · #6 · (Edited)
Also checked for intact photo links.
*MB Do it Yourself repairs.
*DAYLIGHT SAVINGS - CLOCK ADJUSTMENT.
https://www.slkworld.com/off-topic/...d-here-usa-nov-5th-2-am-uk-oct-29th-2-am.html
Where do you buy parts online, and how's the shipping?
*How To Program the Garage Door Opener.
R171 : DIY : How To Program the Garage Door Opener in...
Rattle fix - soft rubber cupboard door bumper.
Relay diagram.
Relay diagram
*how to clear "main inspection performed on time?"
*Emergency Call Button SOS Red Light Solution.
Emergency Call Button SOS Red Light Solution...
INTERIOR
DIY: R171 Shifter console plate
(including shifter position indicator, and mirror & vario roof switches) removal and refinish.
DIY: R171 Shifter console plate (including shifter...
*DIY : Replace steering wheel with one with paddles on.
R171 : DIY : Replace steering wheel with one with paddles on
*DIY: R171 Seat Heater Repair.
Filling vario roof hydraulic fluid and pump location.
filling vario roof hydraulic fluid and pump location.
Repairing the R171 Trunk Divider Pegs.
ENGINE
EXTERNAL
Boot (Trunk) Spoiler Installation Process.
First MOD post... Boot (Trunk) Spoiler Installation Process
Aftermarket face lift mirror covers.
R171 : DYI for aftermarket face lift mirror covers
*AMG 3rd brake light install pdf.
AMG 3rd brake light install pdf contributed by Pr0xyPunk
How to remove a 2005 SLK 350 front bumper.
DIY How to remove a 2005 SLK 350 front bumper
Replacing rear springs and shocks R171.
Replacing rear springs and shocks R171 courtesy mchild
*Curb Alert Pro install SLK55.
R171 - Jacking up the rear of the car, correctly.
Painting Brake Calipers.
https://www.slkworld.com/slk-r171-class-diy/4067-painting-brake-calipers.html
Front bumper gap Sorted 171.
https://www.slkworld.com/slk-r171-class-diy/27914-front-bumper-gap-sorted-171-a.html#post719665
How to install Mud Flaps Slk 280.
https://www.slkworld.com/slk-r171-class-diy/131425-how-install-mud-flaps-slk-280-a.html
Brake bleed SLK 350.
https://www.slkworld.com/slk-r171-class-diy/327145-diy-brake-bleed-slk-350-a.html#post2662577
Brake Fluid Flush DIY.
https://www.slkworld.com/slk-r171-class-diy/11194-brake-fluid-flush-diy.html
Drain Holes Location.
https://www.slkworld.com/slk-r171-class-diy/105562-drain-holes.html
*Retrofit Electrically Folding Side Mirrors.
https://www.slkworld.com/slk-r171-c...trofit-electrically-folding-side-mirrors.html
AC Problem? Evap Temp Sensor Replacement.
https://www.slkworld.com/slk-r171-class-diy/356866-ac-problem-evap-temp-sensor-replacement-diy.html
55 AMG Rear Disc Replacement and Hand Brake problem.
https://www.slkworld.com/slk-r171-c...rear-disc-replacement-hand-brake-problem.html
Lubricate your roof hinges/joints and seals.
https://www.slkworld.com/slk-r171-class-diy/136769-lubricate-your-roof-hinges-joints-seals.html
Replace Mercedes Star Trunk Emblem.
https://www.slkworld.com/slk-r171-class-diy/365978-diy-replace-mercedes-star-trunk-emblem.html
R171 pre facelift front bumper to AMG styling upgrade on a budget.
https://www.slkworld.com/slk-r171-c...-front-bumper-amg-styling-upgrade-budget.html
ROOF
4
Discussion Starter · #8 · (Edited)
Interior
Dash and console
Holding place
*DIY Replace trunk inside filament bulb with LED.
R171 Remove Door Card/Panel.
*Remove centre console and COMAND:
www.slkworld.com/slk-r171-class-diy/395018-slk-r171-video-training-courses.html
*CarPlay for COMAND NTG1.
*DIY: Digital Climate Control & Lower Tray Compartment Installation.
DIY: Digital Climate Control & Lower Tray...
R171 Windrestrictor installation.
Discussion Starter · #10 · (Edited)
USEFUL GENERAL DIYs
https://www.slkworld.com/slk-r171-class-diy/20362-star-service-manual-library-awesome.html#post224533
https://www.slkworld.com/slk-r171-class-diy/208194-mercedes-benz-do-yourself-diy-repairs.html
https://www.slkworld.com/slk-r171-class-diy/479217-restoring-how-tos-r171.html
https://www.slkworld.com/slk-r171-class-diy/8067-diy-how-replace-batteries-your-keyfob-pictures.html
https://www.slkworld.com/slk-r171-class-diy/8352-built-garage-opener-how-program.html
https://www.slkworld.com/slk-r171-class-diy/10678-r171-diy-how-program-garage-door-opener-your-benz-video.html
Solar panel to keep the battery topped up
https://www.slkworld.com/slk-r171-class-diy/492113-fitting-solar-panel-keep-battery-topped-up.html
https://www.slkworld.com/off-topic/473113-heads-up-daylight-standard-here-usa-nov-5th-2-am-uk-oct-29th-2-am.html
https://www.slkworld.com/slk-r171-class-diy/27738-where-do-you-buy-parts-online-hows-shipping.html
Rattle fix - soft rubber cupboard door bumper. MOVE TO RATTLES
https://www.slkworld.com/slk-r171-class-diy/206122-rattle-fix-soft-rubber-cupboard-door-bumper.html
*Relay diagram. MOVE TO ELECTRICAL
https://www.slkworld.com/slk-r171-class-diy/135506-relay-diagram.html
https://www.slkworld.com/slk-r171-class-diy/104417-how-clear-main-inspection-performed-time.html
https://www.slkworld.com/slk-r171-class-diy/366633-emergency-call-button-sos-red-light-solution.html
Discussion Starter · #12 · (Edited)
Urgent help
Sometime we need a quick fix to make the car safe, or get it home.
The following have been gleamed from members posting issues and resolutions.
They are not solutions that I have made.
My thanks to those members who post questions
and most importantly, to those who post resolutions.
First trick, even though it may not make sense...
Disconnect battery for 30 minutes.
This gives all the electrical goodies time to power down completely
& can act like a reset.
Note:- SLKs need a great battery. Less than that and you get electrical gremlins that don't make sense. Save time in the repair shop and always start with battery reset and condition check.
Check the leads from the battery whilst you are in there.
Check fuses.
Even if they look good it is worth swapping over like for like (eg a 5amp with another 5amp).
Never be tempted to put a fuse in with a higher rating than the one it replaces.
This can result in fires.
Fuses are a deliberate weak point put in so you can immediately find the failure
and protects the rest of the circuit.
Worth having an idea of where fuses are located and what they are for.
You could put one of the diy links onto your phone for this very purpose.
Boot lid will not close/lock
Windows will not raise
Try raising all four windows by maintaining the air re-circulation button pressed a few seconds.
Rear windows will not raise
As a last resort the rear windows can be raised by applying 12v and ground to the connectors located in the trunk, if you don’t have accessto a DAS diagnostic system.
Did you use SmartTop to drop the rears?
You have to double tap the lock key to raise them again.
Wipers not working?
Check that the bonnet/hood is properly closed (open and shut it again).
Safety switch prevents the wipers operating if the bonnet is not fully latched.
To be continued as I spot them on the site for the 171.
Please PM me if you spot one.
I am particularly looking for those issues that can leave you stranded and do not need much in the way of mechanical knowledge.
2007 SLK350
boot wiring fixed
We'll that was a cold day spent outside .. but pleased with the results.
First I found an old repair that had failed as they left the joint at the bend point of the wire!
So I then cut the old wiring back and made new joints protected with heat-shrink and new protective cover, pushing the joined wires up into the inside of the boot and then repeated half way down the lower strut (so the joint is protected by the plastic wire cover / protector).
I used a 7 core 'tow bar' cable plus a separate brown wire as that's twice the size of the others. also managed to feed the cable for the reversing camera through the protector at the same time so very happy with the repair :smile:
from
https://www.slkworld.com/general-di...id-you-do-your-slk-today-336.html#post4470463
Reactions: rugroba and Trev5
Discussion Starter · #14 ·
https://www.slkworld.com/slk-r171-c...ing-engine-covers-top-engine.html#post3872385
FLUIDS, FILTERS & ASSOCIATED PARTS
Oil Breather.
https://www.slkworld.com/slk-r171-g...81-resealed-my-leaky-oil-breathers-today.html
https://www.slkworld.com/slk-r171-class-diy/488977-its-perfect-day-do-something.html
https://www.slkworld.com/slk-r171-c...5-oil-filter-change-courtesy-cyberdrakon.html
https://www.slkworld.com/slk-r171-class-diy/31571-slk-200-uk-oil-filter-replacement-images.html
https://www.slkworld.com/slk-r171-c...-change-oil-mercedes-benz-2008-slk-280-a.html
https://www.slkworld.com/slk-r171-class-diy/157489-diy-oil-change-slk350-pictures.html
https://www.slkworld.com/slk-r171-class-diy/4435-diy-oil-change-slk350-pictures.html
https://www.slkworld.com/slk-r171-c...er-housing-oil-cooler-change-seal-change.html
https://www.slkworld.com/slk-r171-c...lant-engines-272-model-171-courtesy-i860.html
https://www.slkworld.com/slk-r171-c...freeze-flush-power-steering-fluid-change.html
https://www.slkworld.com/slk-r171-class-diy/155170-diy-power-steering-wheel-fluid-change.html
https://www.slkworld.com/slk-r171-c...cing-auto-trans-penny-wise-pound-foolish.html
Fuel filter change.
https://www.slkworld.com/slk-r171-class-diy/11054-r171-amg55-green-filter-install-pdf.html
https://www.slkworld.com/slk-r171-class-diy/160417-oil-filter-disassembly.html
https://www.slkworld.com/slk-r171-c...cement-unable-replace-photos.html#post1025058
https://www.slkworld.com/slk-r171-c...nstall-courtesy-dr-eddy-etyu.html#post2548074
https://www.slkworld.com/slk-r171-class-diy/91873-r171-fuel-pump-replacement.html
https://www.slkworld.com/slk-r171-c...ed-oil-separator-drain-pan-housing-cover.html
https://www.slkworld.com/slk-r171-class-diy/28021-05-slk-350-oil-sensor-replacement.html
ENGINE
https://www.slkworld.com/slk-r171-c...ket-cover-slk-200-r171-engine-m271-944-a.html
https://www.slkworld.com/slk-r171-class-diy/363594-water-battery-compartment.html
https://www.slkworld.com/slk-r171-c...-benz-slk-350-m272-engine-throttle-clean.html
https://www.slkworld.com/slk-r171-class-diy/488769-siren-replacement-slk55-amg-2005-a.html
https://www.slkworld.com/slk-r171-c...ittent-windows-fogging-up-caused-bad-sam.html
https://www.slkworld.com/slk-r171-c...k-your-balance-shaft-sprocket-10-minutes.html
https://www.slkworld.com/slk-r171-class-diy/490529-radiator-fan-power-steering-pump-removal.html
https://www.slkworld.com/slk-r171-class-diy/330409-slk-p0015-p0012-p0022-p0025-error-diy.html
https://www.slkworld.com/slk-r171-class-diy/28591-spark-plugs-200-kompressor-m271.html#post303044
https://www.slkworld.com/slk-r171-class-diy/224889-slk-200-tappet-lash-adjuster-diy-replacement.html
https://www.slkworld.com/slk-r171-c...cam-solenoid-magnet-error-code-p0025-fix.html
https://www.slkworld.com/slk-r171-class-diy/226274-idler-pully-replacement.html
https://www.slkworld.com/slk-r171-class-diy/296554-sap-secondary-air-pump-removal.html
https://www.slkworld.com/slk-r171-c...n-shroud-pics-steps-courtesy-reb_tn_06-a.html
https://www.slkworld.com/slk-r171-c...112-113-272-273-motors-most-v6-v8-motors.html
https://www.slkworld.com/slk-r171-c...v-belt-replacement-diy-m112-m113-engines.html
https://www.slkworld.com/slk-r171-class-diy/134082-diy-valve-cover-breather-cover-job.html
https://www.slkworld.com/slk-r171-class-diy/141065-diy-under-hood-led-lighting.html
https://www.slkworld.com/slk-r171-class-diy/175682-diy-vacuum-pump-slk-200-1-8l.html
https://www.slkworld.com/slk-r171-class-diy/204002-r171-change-motor-mounts.html
https://www.slkworld.com/slk-r171-class-diy/26807-diy-r171-spark-plug-change-m272-engine.html
Water in battery compartment. 1 of burning crayon smells
Discussion Starter · #15 · (Edited)
Another Airscarf Retrofit
https://www.slkworld.com/slk-r171-class-diy/553616-another-airscarf-retrofit.html#post4619180
R171 Front Spring Replacement DIY
https://www.slkworld.com/slk-r171-class-diy/554000-r171-front-spring-replacement-diy.html
Motor mounts install.
Discussion Starter · #16 ·
R171 Sticky in case of emergency
https://www.slkworld.com/slk-r171-class-diy/458506-diy-r171-trunk-strut-replacement.html
https://www.slkworld.com/slk-r171-class-diy/16824-diy-r171-smartkey-battery-replace.html
https://www.slkworld.com/slk-r171-c...ps-includes-battery-connection-checklist.html
https://www.slkworld.com/slk-r171-class-diy/32358-diy-replacing-motor-mounts-r171.html
https://www.slkworld.com/slk-r171-class-diy/466569-diyers-your-help-needed-r171.html
https://www.slkworld.com/slk-r171-class-diy/34866-diy-r171-washer-reservoir-removal.html
https://www.slkworld.com/slk-r171-class-diy/239681-diy-intake-manifold-tumble-flap-slk-350-a.html
https://www.slkworld.com/slk-r171-c...tioning-mercedes-slk350-|-between-wheels.html
https://www.slkworld.com/slk-r171-class-diy/5873-diy-service-e-cabin-air-filter-replacement.html
https://www.slkworld.com/slk-r171-class-diy/130833-retrofit-source-hid-install.html
https://www.slkworld.com/slk-r171-class-diy/187817-r171-fuse-relay-locations-pics-descriptions.html
https://www.slkworld.com/slk-r171-class-diy/25313-fuel-filter-change.html
https://www.slkworld.com/slk-r171-class-diy/29773-diy-oil-change-oil-extractor.html
https://www.slkworld.com/slk-r171-class-diy/530419-bodywork-internal-external-facia.html
https://www.slkworld.com/slk-r171-class-diy/11429-7g-tranny-fluid-change-diy.html
https://www.slkworld.com/slk-r171-class-diy/530361-lighting-interior-exterior.html
https://www.slkworld.com/slk-r171-class-diy/1561-green-filter-install.html
https://www.slkworld.com/slk-r171-c...issues-troubleshooting-tree-smarttop-etc.html
https://www.slkworld.com/slk-r171-class-diy/120857-drive-belt-serpentine-replacement.html
https://www.slkworld.com/slk-r171-class-diy/9239-diy-r171-reset-service-indicators.html
https://www.slkworld.com/slk-r171-class-diy/104329-battery-change-diy.html
https://www.slkworld.com/slk-r171-class-diy/221953-slk55-amg-spark-plug-change.html
https://www.slkworld.com/slk-r171-c...-filter-reset-service-reminder-slk55-amg.html
https://www.slkworld.com/slk-r171-c...r-brake-pads-flush-brake-fluid-slk55-amg.html
https://www.slkworld.com/slk-r171-class-diy/117217-diy-replace-cam-sensor-solenoid-gaskets.html
https://www.slkworld.com/slk-r171-class-diy/11652-diy-slk-55-oil-change-pictures.html
https://www.slkworld.com/slk-r171-class-diy/261177-supercharger-oil-change.html
https://www.slkworld.com/slk-r171-c...3-5l-v6-air-filter-replacement-10min-job.html
@jbanks15
@LeonardoDaBenz
If we lose our 171 diy stickies, the list above is what was there.
Discussion Starter · #17 ·
To be added to electrical when ready.
Alternate battery switch installation
1 - 20 of 29 Posts
