Hi my R170 started to missfire. checked spark plugs and #2 present not burned gas.
can anyone recommend a scan tool to check the source of the problem and recommend comon
source of problems to start to check? the misfiring is at all rpm cold or warm
Please update your location in your profile
See my messages and welcome in your intro
Search icarsoftII in google
Search our site
Registered 1999 SLK230
The iCarsoft MB 2 looks like a good scanner, however it will not work on 1999 car. They are working on a fix. The suggested return for credit until it is comparable.
MB C3 Star diagnosis is the best ?
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300, 320, 350, 55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
