Hi.
I have an SLK 170.447 230 compressor. I seriously need help. I been researching my car for 3 months now, the car misfire at 45-5000rpm.
What I have done:
Change sparkplug 2 times different plug.
Chang knock sensor
Fuelfilter, fuelpump
3 diffrent CPS
Change CRP
Try 3 diffrent MAF.
Check injetor
Change coils.
Check vaccum line.
Cleand nozzel inletmanif.
Change O2 sensor.
Check timing on engine.
Sometimes engine start easely (when it is cold)
Sometimes is hard to start, engine can misfire before it start.
Engine runs fine at idle.
Use iCarsoft CR Max as diagnostic tool.
Now faut code.
I'm running out of ideas now🫣.
Thanks everyone for the help😃
What I have done:
Chang knock sensor
3 diffrent CPS
Change CRP
Try 3 diffrent MAF.
Check injetor
Change coils.
Check vaccum line.
Change O2 sensor.
Now faut code.
