1 - 8 of 8 Posts
Registered 2000 SLK200
Anybody tried these, certainly look the business. Are they an improvement from mine which is a Feb 2000 model?
Registered 2000 SLK230
I wish I seen this sooner, I have these on my slk230 they came with them with the guy who had it before. not sure brand or anything though. will get a picture soon. 2000 r170 slk230
As I read up on this I find two questions: 1. Has research found these to be the right ones? 2. How tough is the wiring problem?
A third question: An leakage problems?
Thanks,
Bryan
I bought Sonar Halo Projectors for mine .................
Absolutely no signs of leakage and I live in the the wettest place on the planet rainfall wise, (also the darkest place) ;)
The only issue I had was that when correctly aligned on Dip beam, the Full Beams were too high .....................
Patience, trial and error plus a Screwdriver and some small washers to pack the Full Beam reflector mountings so they angle downwards slightly was the answer, absolutely perfect now ;)
HTH,
HTH,
HTH,
Thanks -and Oregon weather is similar but for dry summers! New problem: Further reading fins that mine is a "pre-facelift" version and involves wiring problems. Ugh.
Just buy from MB Dealer the 2 plastic Connectors and the Terminals that go inside them from a later car, they cost peanuts ;)
They are listed as "Connector repair Parts" on EPC ;)
Premium Member 2002 SLK320
Look great you have to tie in the the halo Positive wire into a existing hot wire and I had to switch the turn signal plug in from my old lights about 1hr job and they look awesome
1 - 8 of 8 Posts
