1 - 8 of 8 Posts
* Registered
Merc slk230 2002
I have a 2002 merc slk230 boot lifts nothing else, locks work on top of windscreen nothing else tries to move or jolt any help greatly appreciated thanks . Plenty of fluid in tank
Is your headliner still in place and your roof closed?
This is almost certainly a switch problem, most likely switch S69/2 or S69/3 is stuck closed. The only ways to tell for sure are to look at them (which you can't do until the headliner is removed) or measure them electrically. Try this though: operate the roof until it stalls. With the soft side of your fist, give the headliner a good rap or two in the front-left and front-right corners. Then try to continue operating the roof. Sometimes (!) this will dislodge a stuck switch.
Lower probablity but still possible: S69/9.
Are you handy with a multimeter?
* Registered
Merc slk230 2002
Discussion Starter · #3 ·
Headliner dropped down to look and both sides do turn and move the locks round seems unless wrong further behind seats unless am wrong
If you look on the left and right rotary mechanisms you'll see each has a very small switch attached; these are S69/2 and S69/3. They have a little rubber cap on them. With the latches unlatched, reach up there and press the switches manually - and see if one (or both) appears stuck.
* Registered
Merc slk230 2002
Discussion Starter · #5 ·
Ok will try that tomorrow thanks and post what happens if anything . Thanks
OK - so you've confirmed S69/2 and S69/3 are not physically stuck closed - that's a good start. You are on the right track with a scanner for the next step - you need to know what the roof module thinks of all the switch settings.
Just FYI, another common failure is the S69/9 "lid open" switch dislodges from it's mounting point. The switch and the mounting point are both plastic. This switch is hidden in the right-rear corner, you can reach in and up to check it.
1 - 8 of 8 Posts
