1 - 19 of 19 Posts
hi,
ive got a 2001 skl 230 compressor with 50k miles.
The handbrake light, ABS, BAS ASR and the brake pad ware indicator light are on the dash, the roof will no go down aswell, it just flashing and when you put it into gear it makes the car jump floward and its stuck in first gear
I took it into a garage I no, they connected it to the diagnostic threw the plug on the engine to be told the rear abs passenger cable was broken so I replaced that myself and 2 pipes off the gear box had broke and needed replacing and because of this the oil in the gearbox was empty, I had these replaced by the garage.
After the garage did the work they then connected it back to the diagnostic and was unable to access the car like it had locked them out so they could clear the faults.
If any one knows of what the problem might be I would appreciate any input thanks
Founding Member 2006
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Discussion Starter · #4 ·
cheers, ive just disconnected the battery, fingers crossed,
already been to mercades today they want £114 to plug it in, I already told them the previous garage said they cannot get into the car so don't think they will be able to but they said ill still have to pay them if they cant read it
hopefully you have your radio code card or you cannot get the radio to work after disconnecting battery
2008 SLK55 AMG "Mabel"
Hi, welcome from Barrhead, Scotland. :smile:
It seems that all MB dealers now want a similar amount to do a "diagnostic check". I could understand it if, after them doing it, you fixed the problem elsewhere, but not if they get to do the work.
Hope you get sorted.
Hi Jeff, just a quick one on the radio code. I am not sure if I have mine, can I read it from the Head Unit before any disconection?
R171s do not need a radio code :D
I doubt any modern 3rd party ones need one also
2005 SLK55 AMG
Hi Craig, and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us! :)
2009 SLK55 AMG
1 - 19 of 19 Posts
