I had a bad (dirty) mass airflow sensor when I bought my 230. I replaced it with a new OEM part for $300. Now it's 8 months or so later and my check engine light just came back on. I know it's not necessarily the same problem again, but in case it is, can I get just as good performance out of one of the $50 models you find online? Can I just clean the current one and reset the fault again? Should I check the oil separator to fix the problem more permanently?
Thanks for the help in advance.
Premium Member 1998 SLK230
Yes you can clean your maf, just be sure to use maf cleaner.
& yes you should check your oil separator.
I have yet to hear of someone getting a cheap maf & it works for mor than a few weeks.
You can also fit an oil catch tank which will minimise the amount of oil in the air inlet tract. Have a search for a thread on how to install.
