Does anyone know a fix for this issue......thanks
Manufacturer Communication No.: LI-58-40
Component(s): ELECTRICAL SYSTEM , ENGINE AND ENGINE COOLING
NHTSA ID Number: 10033070
All Products Associated with this Manufacturer Communication
Vehicle MakeModelModel Year(s)
  • MERCEDES BENZCL5502007-2010
  • MERCEDES BENZCL6002001-2010,9999
  • MERCEDES BENZCL632007-2010
  • MERCEDES BENZCL652004-2010
  • MERCEDES BENZCLK3201999-2009
  • MERCEDES BENZCLK320 CABRIOLET9999
  • MERCEDES BENZCLK3502005-2007
  • MERCEDES BENZCLK5002004-2009
  • MERCEDES BENZCLK552004-2009,9999
  • MERCEDES BENZCLK5502007
  • MERCEDES BENZE3201995-1999,2003-2009
  • MERCEDES BENZE3502003-2010
  • MERCEDES BENZE5002003-2009
  • MERCEDES BENZE552003-2009
  • MERCEDES BENZE5502005-2009
  • MERCEDES BENZE632003-2009
  • MERCEDES BENZG5002003-2007,9999
  • MERCEDES BENZG552004-2007
  • MERCEDES BENZGL3202005-2009
  • MERCEDES BENZGL4502005-2009
  • MERCEDES BENZGL5502005-2009
  • MERCEDES BENZML3201998-2003,2005-2009,9999
  • MERCEDES BENZML3502003-2009
  • MERCEDES BENZML5002002-2009
  • MERCEDES BENZML5502005-2009
  • MERCEDES BENZML632005-2009
  • MERCEDES BENZR3202005-2009
  • MERCEDES BENZR3502005-2009
  • MERCEDES BENZR5002005-2009
  • MERCEDES BENZR632005-2009
  • MERCEDES BENZS6002001-2010
  • MERCEDES BENZS632007-2010
  • MERCEDES BENZS652005-2010
  • MERCEDES BENZSL5001992-2001,2003-2009,9999
  • MERCEDES BENZSL552003-2009
  • MERCEDES BENZSL5502003-2009
  • MERCEDES BENZSL6001997,2003-2009
  • MERCEDES BENZSL63 AMG2007-2009
  • MERCEDES BENZSL652003-2009
  • MERCEDES BENZSLK2301998-1999
  • MERCEDES BENZSLK2802005-2009
  • MERCEDES BENZSLK3209999
  • MERCEDES BENZSLK3502005-2009
  • MERCEDES BENZSLK552005-2009
  • MERCEDES BENZSLR2004-2009
  • MERCEDES BENZSLR MCLAREN2005-2007
Details
0 Associated Documents
Manufacturer: Mercedes-Benz USA, LLC.
SUMMARY:
XENTRY (MERCEDES): ENGINE WARNING LAMP IS CURRENTLY ON OR WAS ON AND A DELAY FAULT OF THE CAMSHAFT ADJUST TO CURRENT OR STORED IN THE ENGINE CONTROL UNIT. MODELS 171, 203, 209, 211, 219, 221, 216, 230, 164, 251, AND 403. NO MODEL YEARS LISTED. *PE
Brake light recall?
http://www.slkworld.com/slk-r170-service-campaigns-tsb/130241-tail-light-recall.html
SUMMARY:
IN ITS LETTER DATED OCTOBER 28, 2005, MERCEDES-BENZ USA STATED THAT IT WOULD CONDUCT A SAFETY RECALL TO REMEDY DEFECTIVE BRAKE LAMP ASSEMBLIES IN MODEL YEAR 1998 THROUGH 2004 MERCEDES BENZ SLK VEHICLES. THE BASE OF THE BRAKE LAMP SOCKET CAN BE SUBJECT TO THERMAL DEFORMATION OVER TIME. THIS DEFORMATION CAN CAUSE MOVEMENT IN THE SOCKET-TO-BULB CONNECTION, WHICH MAY LEAD TO A LOOSENING OF THE ELECTRICAL CONTACTS IN THE SOCKET, AND FAILURE OF THE BULB TO ILLUMINATE. ALL REAR LAMP MODULES (WHICH CONTAIN BRAKE, TURN SIGNAL, TAIL AND BACKUP LAMPS) WILL BE REPLACED WITH REDESIGNED REAR LAMP MODULES WITH A MORE HEAT RESISTANT MATERIAL AND ENHANCED SOCKET HOLDER DESIGN TO WITHSTAND THE HEAT INSIDE THE REAR LAMP MODULE. SEE NHTSA RECALL NO. 05V505 FOR MORE INFORMATION.
Thank for the response.......This issue has to do with check engine and camshaft code lock in the memory of computer even after repair.......its not a recall but it is a manufacturer communication
Brake light recall? here are some search threads
https://www.google.com/?gws_rd=ssl#q=site:slkworld.com+r170+brake+lamp+recall
SUMMARY:
well the communication turned into a recall :D
Thanks for the tail light info......very useful......however my issue is with....... ELECTRICAL SYSTEM , ENGINE AND ENGINE COOLING system........im getting a P0341 code after changing cam sensor, crank sensor and cam magnet......code will not go away.....car runs great however code and light come up and don't go away.....hope someone had that fix available.....thanks
