1 - 8 of 8 Posts
Registered 2004 SLK350
Assume answer is no, but can you change the gear shift buttons on the back of the steering wheel so that one side only goes up and the other down. Really dont like the gear shift currently, all to easy to go the wrong way :(
If not, is there an option to change over to paddles?
Administrator/Founding Member since 2006
mine only goes up 1 side n down the other
Super Moderator (Canada)
2012 SLK55 AMG w/P30
He's got buttons, not paddles. If that makes a difference Jeff. Don't both buttons shift up AND down??
Reactions: jbanks15
Yes got buttons not paddles, so can go up and down either side, pretty pants really he he
Premium Member 2005 SLK55 AMG
Hi All
Yes you can , As you have the Sport Package fitted that's the way they work from the factory . All so i heard someone does replacement Paddles for the buttons . Try doing a search on this forum .
Cheers
Andy
Premium Member 2005 SLK350
Check out G-paddles.com. I can recommend them - super good upgrade. It takes only about 15 minutes to install.
Premium Member 2005 SLK200K 'Little Growler'
I just bought a new steering wheel. Cost £45. Easy install and A mode activation. X
Reactions: i860
1 - 8 of 8 Posts
