1 - 19 of 19 Posts
Hi all
Any tips regarding how to clean and make your dashboard as new?
As you all now, the R171 Dashboard is made of some kind of crispy ruber, and i dont know why it as a kind of shades, no all mat back
Also the doors trims have some white marks where you put sometimes your shoulder
Does anyone know the best way to give that new look?
Regards
Moved your thread to the caring for your slk section
until anyone responds, please 'search' this section for all your questions
Founding Member #2
Earlier models of R171 had a dark grey "rubbery"-like coating that tends to leave lighter grey marks when rubbed by other objects. This was later changed, IIRC, within 1 model year to something that is a little of harder coating with random patterns on the surface.
The earlier type coating on the dashboard molded foam can be cleaned with a damp clean microfiber cloth, then apply a light uniform coat of Aerospace 303. If you want a bit more sheen/shine to the finish, allow the first coat to dry and apply a second coat.
Are the door trims of the same material? Got photo?
I have a 2005 R171 with the annoying dash material. Aerospace 303 is good. Poorboys natural look is what i use now, which works well and has not caused unhappiness over the last 2 years.
Founding Member #2
Were some pictures of the white spots and the not so uniforme black top dashborad
Hope you can help!
Try Aerospace 303 or PoorBoys as Nakulan suggested. I am only familiar with Aerospace 303. May need several applications several days apart: hopefully the colors will blend in, or at least be less observable.
I will try PoorBoys and let you know the results
Shall i use the Poorboys as it comes or diluted in water?
Small amount on a microfiber cloth and spread evenly. If you like a bit more gloss then give another coat. I use it now for the parcel shelf and other black bits too.
Founding Member #2
This "spray-on-cloth-then-wipe method" is best, as one doesn't want to get overspray unto the inner surface of the windscreen or other areas where you don't want the "protectant".
Discussion Starter #13
I All
Just got the PoorBoys from my mail post last week
It's blue, no very liquid and smells like "chewing Gun"...
I started to test in my other car, natural, sprayed in a microfiber cloth, not water added. The look was kind of shinning.
Should i add water for a mate and natural look?
well, owner's manual says to just use water and microfiber
Founding Member #2
Has anyone ever tried olive oil? 1:10 mark
https://www.youtube.com/watch?v=vkgBapTdg2s
The person used the wrong cleaning "solution" to begin with, should not use alcohol or windex (another alcohol-containing solution) on plastics used in motor vehicles, especially clear plastic.
I do like the Extra Virgin Olive Oil solution although I think he should use a lint-free cloth and not the rough paper shown not the video.
I wonder how long-lasting the solution is.
I wouldn't expect Mercedes to suggest anything else other than playing it completely neutral ineffective but safe. It's called covering your back.
Water (distilled) is probably fine when the car is youthful, but with years of UV and oxidation it doesn't condition or restore the surface. My dash and door tops 'need' something, but I'm not sure what to use, here in the UK.
1 - 19 of 19 Posts
