1 - 20 of 26 Posts
* Registered
R170 2000 SLK 230 Kompressor (250000km and counting)
Hi all,
I've had my slk230 for a while. He's about to arrive at his 250000km and I was wondering if anyone had recommendations on what time of maintenance to do.
I was thinking of changing sparkplugs, all car fluids (including gearbox and compressor), change filters.
I'm also ordering some new Wheels and tires for the car (kinda like a present lol) and doing a full paint job. Will these fit?
Front - MSW 25 8.0x18 / 5x112 ET35 MATT TITANIUM TECH
Front - 225/40/R18 91Y
Back - MSW 25 9.0x18 / 5x112 ET29 MATT TITANIUM TECH
Back - 245/35/R18 92Y XL
Thanks for the help
Registered 2004 SLK350
If you kept it up to date with maintenance schedules, would carry on doing that.
Bigger wheels, just need to be careful it does not trash the ride.
Super Moderator (UK)
@Dave2302 will have a good idea.
As said above, much depends on previous maintenance history.
Rubber parts deteriorate with age. That covers lots of parts and well worth inspecting all bushes and gaiters.
And congratulations on the mileage. (Over 150K miles for imperialists).
* Registered
Unfortunately, i don't have the service records. When i got it i just kept on doing the normal maintenance (oil and filters), so i was thinking of doing a big check of everything.
Probably time to renew all fluids that you have not done, brakes, power steering.
Couple of links for other stuff:
Roof
I'd use the buyers inspection guide as a starting point:
did i miss it or you do or do not have your r170 maintenance manual with time and mileage service tasks?
* Registered
2002 SLK32 (x1), 2003 SLK230 (x2)
Change the roof locking hydraulic cylinder seal, if you haven't already.
High probability of failure, and if it does will ruin a $400 headliner, that is very hard to find replacements.
Larger wheels will reduce ride quality. Heavier wheels will noticeably slow the acceleration.
When I got my lady, I changed everything serviceable even with full service history still changed it all so I knew when it been changed so could reset the schedule.
* Registered
thank you for the manual. I added the Rear diff as said by Mn car guy.
I've just sent an email to a company there in the US and will be sending my hardtop hydraulics to be rebuilt. actually really cheap
18" Wheels with decent tyres do not ruin ride quality, sure it's a tad harder, but doesn't rattle yer skeleton, and I'm an old git with Arthritis ;)
Normally I'd run Avon ZV7's on all my cars, but due to the Rear Tyre size being unavailable in Avon in the UK, I used Uniroyal Rainsports on mine 255 / 35 x18 rears and 235 / 40 x 18 front's on my V8 R170, sticks well (considering the power to weight), and rides good too, Billies B4 Shocks all round and CLK 500 front springs, stock SLK320 Rear springs, and I've swapped the Spring Pads to tailor the ride height ;)
Reactions: Icepilot
Registered 2006 SLK280
Stuff to consider
Shocks/struts
Serpentine belt
Pulleys (idler/tensioner, maybe harmonic balancer)
Thermostat
Water pump
Engine coolant
(Maybe alternator while you’re there)
Shocks/struts
Brake fluid
Rear diff
Motor and transmission mounts
Power steering fluid
Engine and cabin air filters
Transmission fluid and filter
Engine oil/filter
Sea foam spray intake cleaner
Sea foam engine oil treatment
Registered 2001 SLK230
Please advise name of that company.
* Registered
Time the open and closing of the hardtop, supposed to be about 25 seconds. If significantly longer, the hydraulic pump may be worn out. Could change while addressing hydraulic cylinders.
In my experience of 5 R170 cars, only the roof cylinder seal has ever leaked on 3. And changing the seal with cylinder still plumbed to car is much simpler than complete removal. I now change this seal proactively on every car before it leaks.
Happy Motoring,
R
* Registered
One more...
Clean out oil separator on engine air intake system. These clog and allow oil into the intake tract, which is a little messy and can contaminate the mass air flow sensor.
* Registered 2001 SLK230
Mercedes Benz slk amg 2001
Hi all,
Thanks for the help
See if u can find amg wheels they look really good.
1 - 20 of 26 Posts
