Maf sensor
194 Views 7 Replies 6 Participants Last post by  jbanks15
Hello everyone
I have the following problem, my MAS senser needs to be replaced. And I read a lot of problems with the after market models.
So I'm going to replace it with the original. But my EPC folder won't open anymore and so I can't find the OEM number of this part.
Can someone look up this part number for me? The VIN number is MDB1714421F053973 (slk r171 200 year 2005)
thanks in advance for your help
Reactions: 2
1 - 8 of 8 Posts
I suspect that part number is incorrect (MDB=WDB).
You can look up parts here:
Great Thanks and indeed wrong VIN number sorry
Reactions: 1
For anyone reading this at a later point, after market MAF sensors are known to be .. "bad".
We all recommend to "pay the piper" and get an original MB sensor! That goes for other sensors in and around the engine: CAM/CRANK shaft sensors, but also the speed sensors at the wheels..
Reactions: 2
Bosch will do fine, is @ £90 for my car from autodoc.co.uk and £400 at main dealer...
  • Wow
Reactions: 3
+1 for using Bosch.
side note: sometimes takes a week or two for autodoc to deliver for uk BUT every item has feature where you can ask about fittest for your vin.
For EU delivery should be better.
Reactions: 1
Pierburg is algo a good choice, don't know the price in your country.
Reactions: 1
Here is part number per your vin
A 271 094 02 48
MASS AIR FLOW SENSOR
1
Quantity: 1
See less See more
Reactions: 1
1 - 8 of 8 Posts
