1 - 19 of 19 Posts
hi guys,
Advice needed please, I have a mis fire on my r170 slk 320 on cylinder 6
I’ve changed the spark plugs and checked leads and swapped injectors which still hasn’t cured the problem? Any ideas?
misfires usually 4 things
sparkplugs
ignition wires
coil
injector
did u check/swap coils?
The car will run perfect below 4000rpm once reset, only happens under hard acceleration
Hey just curious, do folks ‘gut the cats’ on these cars? No, I am not condoning or suggesting it just wondering.
Discussion Starter #13
Is there a reliable fault code list somewhere as I keep seeing different answers re p2054
Super Moderator
In corroboration of post 12
https://www.obd-codes.com/p2054
I find the trouble with P codes is that they are somewhat generic in nature and not an MB specific code. Hence your query.
Super Moderator
That refers to diesel fuel??
Ahh, so you noticed :wink: That's what I was trying to (subtly) illustrate about diagnosing generic P-codes. :tu:
1 - 19 of 19 Posts
