Registered 2009 SLK350
New to me SLK350. There are three or four lug bolts that have a 17mm head that fit the factory wrench. All the rest are very large and fill most of the hole on the wheel. Are these covers that come off or is this an alternate lug bolt? What is the right socket to fit in the wheel? None of mine have a thin enough wall.
570793
Registered 2007 SLK55 AMG
I made a similar post recently with the same question. Once you remove your plastic lug caps you’ll have access to the 17mm lug bolts.
