I have a 1999 R170 recently bought. At times the indicators will stop working and the warning light will display on the panel. After much searching I find that by moving the main lightswitch/fusebox I can make the fault come and go as I like. has anybody any experience of this? and can you suggest the cure. it would be useful if someone had a wiring diagram to show me. Is there a ground point in this area? All other functions are OK.
Until the clever folk arrive:
When you say 'searching' do you mean of the forum.
Start your search 'SLKWorld.com' to get more relevant results.
http://www.slkworld.com/gtsearch.php?cx=partner-pub-7865546952023728:9jt0y7-sz5j&cof=FORID:11&ie=UTF-8&q=slkworld.com+R170+wiring+diagram&sa=Search
Also, if you check the service bulletins there was an issue with connection corroding in the tail light (may/may not be relevant).
SLK R170 Service Campaigns (TSB) - Mercedes Benz SLK Forum
R170 Encyclopaedia.
http://slkworld.com/r170/home.htm
I don't think it has a wiring diagram but there is a component location list that may help.
Good Luck
Myk means I think
go to google
type
site:slkworld.com r170 'search words'
