1 - 20 of 25 Posts
Wanted to buy my first Mercedes so I thought I would try and find an SLK. Maybe you guys can offer me some do's and dont's of buying one. I have a scanner so I'm going to try and check the codes before buying. Any advice would be appreciated.
so is the car u r looking at/getting the 2000 slk 320?
Welcome from Wirral, England.
We have a free to enter monthly competition.
Entry is normally open from the 1st to the 15th of every month. You simply post a reply with 3 photos.
After the 15th we usually open a poll for members to vote on their favourite.
Here's the main thread:
http://www.slkworld.com/rotm-submissions-voting/
New members are welcome to enter (and they win too!).
Voting is open for the 2018 March Ride of The Month.
PLEASE NOTE :- Voting closes on 31st March.​
Really useful links (thanks to ixions cataloguing)
http://www.slkworld.com/general-discussion/354330-links-toparts-assemblies-technical-data-locations-parts-slks.html
https://slk-links.neocities.org/ Includes diy videos.
A brief guide to the forum and how to get the best from it:
http://www.slkworld.com/new-members-introduce-yourself-here/439993-new-wondering-what-do.html
There's a link to R170/171/172's do it yourself threads under the pic below.
CA threads: U.S. California - Mercedes Benz SLK Forum
Do this before test driving: http://www.slkworld.com/general-discussion/70666-reset-transmission-adaptive-learning.html
Check list: http://www.slkworld.com/general-discussion/68666-new-used-vehicle-pickup-checklist.html
Roof care: http://www.slkworld.com/general-discussion/20937-spring-here~gummi-pflege-lube-your-seals-lithium-grease-your-joints-hinges.html
My favourite mod: http://www.slkworld.com/general-discussion/121481-what-smarttop-all-members-keep-talking-about.html
look for one that's maybe on Mercedes used lot
Welcome from Canada :smile:
____________________
Len
Registered 2000 SLK320
Wanted to buy my first Mercedes so I thought I would try and find an SLK. Maybe you guys can offer me some do's and dont's of buying one. I have a scanner so I'm going to try and check the codes before buying. advice would be appreciated.
The 320 engines are fairly reliable, CEL usually caused by faulty electrics, usual fault codes relate to,
Secondary air,
Camshaft sensor,
Crankshaft sensor,
Missfire, random or a specific cylinder and plug.
The K40 relay can also cause CEL to come on.
Try and get a list of the fault codes then look up on the OBD2 website.
There are a lot of faults that do not cause the CEL to come on so there may be quite a list stored in the ECU.
Welcome to the forum from South Yorkshire.
Regards Stuart.
Premium Member 2009 SLK55 AMG
Discussion Starter #16
Thanks! Im picking up my first one tomorrow! Hopefully we can get thr CEL off without too many problems. Does anybody know about updating the computer?
Welcome from Lakeland, Florida.
Good luck and have fun shopping!
Registered 2012 SLK350
I'd have some concern with a CEL unless the price was very very good. In Calif its the sellers responsibility to make the car pass a smog check, with the caveats that a registered non operational doesn't need one, and if it won't pass a smog check the main recourse is to get your money back and not buy it.
My experience is that turning off the CEL is easy, any cheap scanner should do a reset, but it still won't pass smog check until all the subsystems test internally as good and that can take 50 miles of driving for some.
I use a few scanners, cheap wired unit, $400 wired fancy just for Ford unit, and a bluetooth that works with my Android phone and various software packages. Depending on your mechanical expertise the cheap one may give you codes you can look up and figure out what to fix, but it may not locate the specific part in a system that is bad. Generally the more expensive the scanner the more it walks you through needed repairs and performs additional "factory type" tests to narrow problems.
Premium Member 2005 SLK55 AMG
Hi and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us and posting an intro! :)
1 - 20 of 25 Posts
