1 - 10 of 10 Posts
Registered 2007 SLK280
I am trying to locate install instructions for a 2007 R171. I recently acquired a set of OEM Illuminated door sills, but they do not have install instructions. Hoping to avoid paying the dealer...
Founding Member 2006
I am pm'ing you.
Try these and also read your private message
click on installation link
ForMyMercedes.com
procedure should be the same. I have another set of instructions, also not mb, but power to illuminate is power. should be very similar. oh well, i tried
Craige (Curro101) makes his own illuminated door sills and maybe can confirm how his is installed
send me your email and i will send you the other set of install instructions
2004 SLK200K
I fitted a set of those a while back.
As far as I can remember it was just a matter of supplying a 12v permanent source, which I took piggybacked fro the dash end fuse box and then you just remove the door switch connectors and plug them into the "opposite gender" connector on the harmess, connecting the other connector back on the harness to the switch.
I ran the wiring behind the rear wall carpet, through the bottom of the centre console and over to the passenger side.
1 - 10 of 10 Posts
