21 - 29 of 29 Posts
Registered 2002 SLK 230 R170
Discussion Starter #21
Hi Everyone, :grin:
In case you have never come across it on the site there are Two Pages of Invalueable Information SLK Information available with just a click.
The FIRST Page
There are Over 50 Links to sites with SLK Information on them
List of Useful SLK Links >
https://slk-links.neocities.org/Links.html
Visit it to get Parts Details & Numbers, Tips,Assemblies, Technical Data and the Locations of Parts for ALL SLK's.:grin:
You can look up -
Part No's, By Group & Subgroup. Giving you - Description & Exploded Diagram for Assemblies.All SLK are Covered.
Location of components - Diagrams & Pictures
Technical Service Bulletins
Wiring Diagrams
EXAMPLES >:smile:
Just ADDED-
***NEW*** Wiring Diagrams & Technical Service Bulletins. Enter the Year, Make& Model of your Car.
Then select the system for TSB's or Wiring Diagram. **A PDF READER IS NEEDED FOR THIS LINK**
***NEW*** Mercedes-Benz Specifications for Operating Fluids (MB BeVo).
***NEW*** Color Codes - All Original Mercedes SLK 170, 171 & 172 Paint Cross-Reference.
***NEW*** Mercedes-Benz SLK 170,171,172 Specifications.
***NEW*** Used Mercedes-Benz SLK buyers' guide .
***NEW*** Mercedes Specialist Finder. (Multiple Categories UK ONLY.
***NEW*** BenzShops.com is a directory of independent Mercedes-Benz mechanics in the USA.
I've moved the Last Two up to the top as it's a common question on the forum.
***NEW*** U.S.A. Remanufacturer of original European Automotive Electronics.
***NEW*** U.S.A. BBA Reman is one of the worlds leading Automotive Electronics Remanufacturers.
***NEW*** UK Specialist in Refurbished Electronic Automotive Parts & Repair.
R170 SLK Roof Cylinder's Rebuild Guide with Cut-Away Diagrams (DIAGRAMS On Third Page).
Supercharger Removal.
Eaton m62 supercharger rebuild & porting.
IMPORTANT R170 SLK Hidden Potential Rust Trap.
Jacking Up Your Car.
Replacing Your Engine Accessory Drive Belts.
MAF Sensor Cleaning.
Exhaust Manifold Removal.
Supercharger Oil Change.
Oil Level Sensor Replacement.
Tyre & Wheel specs for all Mercedes-Benz SLK-Class series. 1996 - 2016.
Custom Rim & Tire Size Calculator..
SLK 230 Head Gasket Remove & Replace.
Checking for Battery Drain.
Mercedes Benz Transmission Problems.
The Correct way to Jump Start a Mercedes Benz.
Mercedes-Benz SLK: Painting Interior Plastics.
10 Things All Mercedes-Benz Owners Should Know.
Mercedes SLK (Model r170) - Buying a good one.
And Many More
The SECOND Page >
Contains MercedesBenz Exploded Diagrams and Part Numbers of All SLK Models and Variants
PARTS Information on Mercedes SLK R170 R171 R172 >
You will never need to ask about part numbers again.
Go On - Have a Look .FEEDBBACK WELCOME
Regards
Mike
Discussion Starter #22
Hi Everyone, :grin:
In case you have never come across it on the site before there are Two Pages of Invalueable SLK Information available with just a click.
The FIRST Page >
Contains MercedesBenz Exploded Diagrams and Part Numbers for All SLK Models and Variants
The SECOND Page >
There are Over 60 Links to sites with SLK Information on them
Visit these PAGES to get Parts Details & Numbers, Tips,Assemblies, Technical Data and the Locations of Parts for ALL SLK's.:grin:
You can look up -
*Part No's, By Group & Subgroup. Giving you - Description & Exploded Diagram for Assemblies.All SLK are Covered.
*Location of components - Diagrams & Pictures
*Technical Service Bulletins
*Wiring Diagrams
EXAMPLES >:smile:
Just ADDED Today-
***NEW*** UK BASED BBA Reman is one of the leading auto Remanufacturers. ABS ECU modules, throttle bodies & cluster repair Etc.Company was founded in 1998.Lifetime warranty offered..
***NEW*** UK BASED A Complete Solution to Key Fob Problems - Offer a NO Fix NO Fee policy..
***NEW*** UK BASED Remote Key Repairs.
***NEW*** UK BASED Remanufacture - ABS ECU modules, throttle bodies & instrument cluster repair.
***NEW*** UK BASED Instrument Cluster Repair Services.
***NEW*** UK BASED Electronic Remanufacturing Since 1988 ECU,Clusters, ABS,Etc.
RECENTLY ADDED -
A SELECTION OF OTHERS
SAMPLES OF OTHERS -
HERE ARE THE LINKS AGAIN -
Go On - Have a Look .FEEDBACK WELCOME F)
Regards
Mike
Discussion Starter #24
Major Upgrade to INFO Site
Hi All,
Just finished a Major Upgrade on my SLK INFORMATION Site that Covers All MODELS R170 R171 & R172 :grin:
To make the best use of this you need Need the Chassis Number.
There are 3 Main Pages in the Site -
Page 1/
Main Page. You can find here the Part Numbers for the items that are in your Car, and Illustrated Details of how assemblies go together.
Available to access by Chassis No or Car Model
https://slk-links.neocities.org/ :smile:
Page 2/
60+ LINKS TO OTHER SITES WITH SLK INFORMATION.
Everything from finding Professional Remanufacturer of original Automotive Electronics to MAF Sensor Cleaning & Roof Piston rebuilding and a lot lot more.
https://slk-links.neocities.org/Links.html :smile:
Page 3/
Fed Up with paying Stealership prices.This Parts Catalog allows you to find Aftermarket Mercedes SLK parts suppliers and their Numbers for the parts.
These are the People who supply OEM Parts so Quality is not compromised.
This Catalogue is from a German Company so depending where you live you may have to search for the supplier in your Country
Suppliers Listed Include - Bosch, Borg & Beck, Lucas, Febi, Hella, GE, Swag, Mintex, Metzger, Quinton Hazell - TO NAME A FEW
https://slk-links.neocities.org/PARTSCLUB-1.html :smile:
Wow, what a great idea and info. I do not have the SLK, wanted a luxury car to carry me and golf clubs and mates around, but I will still have a look in depth at the info there must be some compatible bits there. I have only looked briefly at MBworld etc but if there is some-one who has done this for my merc on there I'll have to search in more detail.
Note to all who have replied to my introduction, a BIG THANKS, for making me feel so welcome, even without a SLK.
Daperskin
Bump to the top!
21 - 29 of 29 Posts
