1 - 13 of 13 Posts
How can I tell if my car has linguatronic, my steering wheel has the button but when I press it all that happens is the sat nav comes up on the screen I have audio 20 with Becker map pilot. I don't have comand on the audio 20 and also there is no sd card slot on the front of the radio facia.can anyone clarify which radio model I have is it nt4.5
Founding Member 2006
2017 SLC43
If you have the Becker unit, and you have enabled voice input, it should work. Have you enabled voice input on the Becker settings screen (it's a crude picture of a head with sound waves coming off it)? It will be greyed out if it's switched off.
But before you get your hopes up, it's pretty poor. Although that could be my Scottish accent!
SLK Disposed of
How can I tell if my car has linguatronic, my steering wheel has the button but when I press it all that happens is the sat nav comes up on the screen I have audio 20 with Becker map pilot. I don't have command on the audio 20 and also there is no sd card slot on the front of the radio facia.can anyone clarify which radio model I have is it nt4.5
I think it only works with your nav if you have Becker map pilot, need comand for it all to work, was reading about this the other day but can't find the link now.
2017 SLC43
Surely you either have COMAND or the Becker? If you have a slot in the glovebox you have Becker (not in the USA where the Becker prep was an option) but in general most folks have Becker in the UK and it absolutely, definitely, works with the voice button, certainly on anything from MY2013 BUT you do have to enable voice on the NAVI screen.
Discussion Starter · #7 ·
OK yes I have Becker in the glove box and it does work with the voice command button on the steering wheel I was mainly refuring to how I could voice command any other items I could control with the button ie the phone as I have Bluetooth as well . Cheers guys for the info so far
2017 SLC43
No, that's all it does. What else did you want it to do?
Discussion Starter · #9 ·
OK cheers ,obviously I don't have linguatronic voice command then,on my last ford focus you could do volume, change cd,or track ,dial a name all from one button with Bluetooth
SLK Disposed of
Why are you having a pop at me I was only trying to help Black Knight. I know what I have I have comand and I know how it works and how to use it thank you.
2017 SLC43
If I have caused offence then I apologise unreservedly. It was most certainly not the intention.
I think there is some confusion arising from the original post in that from what was written appears to indicate that the voice button on the steering wheel did nothing but switch to the NAVI screen and took no voice commands at all, when apparently it did allow the OP to operate the Becker unit.
Had the OP typed that he could operate the navigation but nothing else, that would have saved a lot of wasted effort.
Please be assured I was not having a pop, simply trying to clarify the fact that you either had one system or the other.
Discussion Starter · #12 ·
Thanks for all your help guys and sorry for not been clear on the subject in hand, don't think it was not a wasted effort as I still have learned a lot from your comments and so will any newbees
Reactions: wja96
SLK Disposed of
Thank you very much for your apology I may have over overreacted Rob.
1 - 13 of 13 Posts
