Went into the limp home mode tonight. After getting home I read through the manual and this site, then went back out and restarted the car and took a test drive. Everything was fine in both the C and S settings, and both auto and manual shifting.
No idea what caused it to go into that mode but will stay tuned-in to driving conditions, etc., in case it happens again.
Discussion Starter · #2 ·
Happened again today, although I've driven 150 miles since the 1st occurrence without any problem. I stopped and turned off the ignition, waited 2 or 3 minutes and restarted, Drove fine for the rest of the day.
Founding Member 2006
* Founding Member #2
2008 SLK55 AMG
Best to have error code read by MB.
Discussion Starter · #5 ·
Thank you Jeff. Will take to dealer to check codes and change the plates if needed.
Most of the linked threads looked like AMG however I'm non-AMG. Also will try to reset the computer by using the "key on" sequence as provided although I assume this is a temporary fix not permanent.
