1 - 20 of 20 Posts
Hi all.
The SLK is finally with me, still without italian plates. Hopefully I'll get them in a couple of weeks. In this spare time, it's a good idea to do something for both cosmetics and mechanics.
There's no rust to deal with, which is a good starting point; a few minor components need to be replaced, the most important is a tension rope for the Vario Roof.
BTW does anyone know where I can find the two stickers close to the petrol cap and which is the part ID?
TIA,
Guido
Registered 2009 SLK200
Hi all.
Ooohhh Alfa Spider :surprise::surprise:
Yes, it's a 1971 Spider 1750 Veloce Iniezione. It was first imported in Italy in 1991 from USA, mine since 2000. Now it needs some works. I've been working on the engine, mainly on Spica injection; it has to be fully repainted, because it was born in AR008 biancospino (white). I don't know when it was painted (not very well, to be fair) in red: surely before I bought it. BTW the Countach you can see in the background, unfortunately, is not mine ;).
OT, some pics of the Alfa.
Yes, it's a 1971 Spider 1750 Veloce. It was first imported in Italy in 1991, mine since 2000. Now it needs some works. I've been working on the engine, mainly on Spica injection; it has to be fully repainted, because it was born in AR008 biancospino (white). BTW the Countach you can see in the background, unfortunately, is not mine ;)
I had one 1750 still got the rear chrome boot badge .
And a 1985 S3 spider in Rosso Red stored . :grin:
Spica injection mmm a nightmare ?
Believe me, it's not a nightmare. It's reliable if properly tuned up. I had a Montreal until 2006: no troubles at all with the two Spicas, a lot with the head gaskets (I had to install the ones of a Giulietta Turbodelta). Luckily I have a lot of spares related to Spica, such as the water pump - which is not the same as the carburettor version - and the temperature sensor.
Super Moderator 2006 SLK 280
Hi all.
TIA,
Guido
Parts list with numbers is in the attached PDF
Yes, it's a 1971 Spider 1750 Veloce. It was first imported in Italy in 1991, mine since 2000. Now it needs some works. I've been working on the engine, mainly on Spica injection; it has to be fully repainted, because it was born in AR008 biancospino (white). I don't know when it was painted (not very well, to be fair) in red: surely before I bought it. BTW the Countach you can see in the background, unfortunately, is not mine ;).
Was originally white ?
@WoZ53
Many thanks for your list: I really appreciated it.
It was easy to spot the ID of the horizontal sticker (unleaded fuel in german: A 210 584 90 17).
Unfortunately I can't find a match for the vertical one: may I have a hint, please?
TY
Guido
@WoZ53
TY
Guido
Guido, I'm not really sure what that sticker is. It translate in English to
Switch off the gas pump nozzle multiple times
Yes, that's the one I meant. My English is not at its best, but my German is even worse, so Google Translator was my friend >:D
BTW, I'm really happy of today's efforts: at last I installed the factory radio and the car itself has been (almost) polished by my mechanic. I must guess it will be painted in a couple of days.
Discussion Starter #13
About the paint job, it's not that easy. The hood was sprayed recently: it's the first thing catching the eye on a SLK. Thus I decided to spray 4 samples in brilliantsilber (each one for the colour variants available). I can't know what paint brand was used; the difference between different brands is often visible. Since I don't want to spray the whole car (I'm more focused on the Alfa) but I'd like to get a good result, the goal is to tune the most similar colour with the bonnet for left and right side of the car. I must guess my mechanic won't love me so much ;)
Discussion Starter #14
Going on with the sanding: a little quantity of filler was needed, but the car was (I should say IS) in good conditions. The rims don't need to be refurbished, already in very good conditions. Meanwhile, all the spares for a serious service are on the way to Italy ;)
Discussion Starter #15
Well, it's not the best job ever seen, but it's what I was looking for.
If you stare at the car, you can see some minor flaws; yet the result for a cheap job is really satisfying. Only the right and the left side and the rear bumper were painted. The amount due is under 750 USD.
Here are some pics.
Discussion Starter #18
I'm sorry, the vertical sticker is for sure a horizontal one: my mistake.
I think the sticker refers to noozle, because the word "Zapfpistole" means "noozle" in German.
Guido
Guido
Hey Guido, it's nozzle :wink:
Reactions: sintoni
1 - 20 of 20 Posts
