1 - 2 of 2 Posts
Searched the threads looking for instructions/photos for removing and replacing the left door mirror housing assembly. Can someone direct me to this information if it exists and if not, can someone explain how to remove the inside triangular trim piece that sits just above the upper front corner of the left door panel?
I've tried pulling upward on it and it does slide up, but won't come off. I'm concerned that too much pressure in the wrong direction will break it. The mirror housing itself appears to be held on by three screws from looking inside the door panel after removing the small plastic access plate. If I could get the upper triangular trim to come off, I think the replacement from that point would be fairly straight-forward.
Any help appreciated.
benzer101,
Thank you,
Moderator/Founding Member
1 - 2 of 2 Posts
