1 - 8 of 8 Posts
Patiently waiting for darkness to see how effective the new LED Reversing lights are on Silkie....
Truely a two minute job to change the lamps over - but no way of knowing how effective the lamps are in the bright sunshine....
Sent from my Xperia while my back was turned
Premium member 2018 SLC43
Wonder'f that would help a 2102 SLK 350. Mine are so dim you have to hold a candle up to them to see'f they're on. I use the brake lights and rear fog light to see where I'm going. Guess they're for signaling and not illumination.
Hi, was it just a straightforward bulb replacement Savcom? What did you replace them with?
Thanks,
Dez
Initially it was, but I have the bulb warning light lit so I need to work out what resistors to put in place.
My goodness they're bright!
I have been remiss. I've not updated this since completing the work.
I ordered these LEDs from eBay - apparently "2x Bulbs Reverse 15Smd LED P21W BA15S Bright White 750Lumen Canbus Mercedes"
The price has gone up since I bought them though.... :surprise::surprise::surprise:
That said, I've a few thoughts I'd like to share about them.
Firstly I looked long and hard and tried to pick a lamp that would put the most light out in the direction I wanted - i.e. straight back - owing to how the old lamp sat in the holder. These definitely throw the light where you want it!!
Secondly, having seen the bulb fail lamp light up I measured the power consumed by each lamp - this was a shade under 7W per lamp (the lamps drew 0.483A at 13.8V). That's not nearly enough to fool CANBUS logic - hence the bulb failure warning. However, the light produced is a marked improvement on the old incandescent versions and worth the upgrade despite the extra hassle of adding resistors. I added 2x 12R 25W resistors across the brown and grey/yellow cables in the rear lamp harness (see diagram below).
Finally, I suspect it would have been a bit cheaper buying non-CANBUS lamps and adding the resistors myself. :nerd::nerd:
I've more photos of the resistor fitting so I'll pop those in a new post on this thread.
To finish this thread, I had to fit resistors to fool the car that the lamps had not failed. This took me 30mins - including photographs!
First the problem:
Next the kit (I made these - but you can get ready-made kits for a few pounds/dollars from most motor factors or Amazon)
I took out the nearside loom to do the install:
The wires you need are the Brown and the Grey/Yellow (see wiring diagram above - but don't forget my car is a facelift so check the colour codes for your car before crimping!)
Here is the resistor attached to the nearside loom:
I repeated this process with the offside loom (there is an extra cable on this loom for the rear fog lamp - but you will still need to put the other resistor on the Brown and Grey/Yellow cables) and tested the car again. That's better!
Note the before and after times on the clocks!
I am on the same boat as you...thinking we need to get those None-CANBUS Error free LED bulbs everyone keeps talking about for our cars.
1 - 8 of 8 Posts
