I'm searching for led indicator bulbs for my SLK R171 (front and rear).
I've searched the forum and I've seen someone mention Cree indicator bulbs. Where can I find them? Is it only a bulb (with build in resistor) or does it come with an extra resistor assembly?
- LED
- Amber/Yellow color
- Build in resistor (error-free canbus)
e-bay for example has a lot of choices, but which are the better ones?
These reversing LEDs are excellent - properly bright and no heat problems. Also great with the SmartTop rear courtesy light function: https://www.ebay.co.uk/itm/2x-15smd-P21W-Reverse-Led-Cree-White-6000K-Canbus-Mercedes-SLK-R171-2004-2011-/173364736850?hash=item285d57f352
These sidelight LEDs keep failing but are cheap enough to have spares: https://www.ebay.co.uk/itm/FRONT-PARKING-SIDELIGHTS-501-T10-194-W5W-CANBUS-5W-CREE-WHITE-SMD-LED-HID-BULBS-/131214317482?hash=item1e8cfb97aa
The indicators have been fine for 7 months and still going strong. It's a German car and therefore indicators are optional anyway(!): https://www.ebay.co.uk/itm/44-Led-Canbus-Error-Free-581-Bau15S-1156-21W-Bulbs-Indicator-Amber-Offset-12V-/131600116692?hash=item1ea3fa6bd4
Disclaimer - these have worked for me and I think the links are correct!
Thank you for the information. I will order them and try them! Do they differ from the lamps in the side mirrors? In color and rythm?
I think it's fair to say an LED replacement will never look quite the same as the purpose-built/designed lamp; however I like the crispness of the flash. Yes, they flash at the same time/rhythm as far as I can see.
