Hi everyone
I have just got an SLK 320 could you help me with two problems
Driver side leak at roof join (any hint at a cure please)
How to replace speedo illumination lamps
Thanking you all in anticipation
Hi & welcome!
There is a thread for your problem...
You have to loosen the seals and to stretch them forward... 1-2mm
Than you tighten them,and ure ready!
Tesla,
Moving to r70 general discussion section
Thank you,
Moderator/Founding Member
