Oil leak from front of engine block ?Kompressor - 230k
Hey guys... after some help.
I seem to have developed an oily leak in front of the main engine block. Having no idea what i'm looking at can anyone suggest what this may be and how to repair? its dirty looking :crying:
Cheers Kayden
2005 SLK55 AMG
Kayden, I can't help with the oil leak or kompressor issue, so hopefully other members will be along shortly to offer their help and advice.
In the meantime...
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If iPhone pics, you need to rename any additional pics as iPhone names its pics all the same, image.jpg.
Given that you only have 6 posts, you need at least 15 posts (and give the system time to update) before you can edit one of your posts (or send private messages to anyone other than moderators)...
You can, of course, add a new post to this thread and add the pictures to that using the notes above. :D
Edit: Great to see you've got your post count up, and have been able to edit and add the pics to your post. :tu:
Registered 2000 SLK320
Cheers Kayden
Hi and welcome Kayden, looks like the crankshaft seal is also leaking as well, buy some gunk or jizer degreaser use a 1" paintbrush and work it into the black crud until it dissolves then wash off with low pressure hose, dry the area down with paper towels, then check for new leakage from both areas over the next week or two if its behind the crank pulley then new seal required, If its from the camshaft sensor then I have no idea, someone else will have the answer to that one.
Regards Stuart.
2019 SLC300
Camshaft adjuster is leaking. You need to get this fixed as the oil will wick into the wires and to the ECU. In the USA there is a dealer fix and a patch that would prevent any future leak from oil to wick into the wires.
Discussion Starter · #6 ·
Cheers Kayden
Regards Stuart.
Thanks Stuart... I'm gonna give this a go this afternoon and check throughout the week. I have suspicions she's gonna need a trip to the Doc's but at least I'll have a better idea of what it is. Update next week.
